chr15_7_t_ Posted February 1, 2010 Posted February 1, 2010 hopefuly within a week..2 at the most my car will be runing the folowing so just wondering if il be ner fuel cut..stainles mani (think its a cheap one tbh but my standard one has a real bad crack and i got this stainles one for £20 )decatair filter relocationa/b fmicported ct9b turbocustom exhaust but i think it is about 2" straight through to the back box Quote
ste91 Posted February 1, 2010 Posted February 1, 2010 You could do but if the wastegate on the turbo is ported big enough it should be able to let enough exhaust gas through so that it doesn't creep. Set your actuator to 11-12psi and see what happens. IIRC fuel cut is 12.5psi so it's possible that you could get a little creep on very cold days. Quote
chr15_7_t_ Posted February 1, 2010 Author Posted February 1, 2010 cant adjust my actuator yet stil standard lol... was just worried incase on a cold like your saying.looking for an adjustale actuator though Quote
Jae-Glanza Posted February 1, 2010 Posted February 1, 2010 I'm running same setup but havent fitted my mani/decat yet and i have an hks actuator, From what i can gather, i'll be fine running that setup without fuel cut aslong as i adjust the boost to suit.. (lower the boost using hks actuator) However, you haven't got an actuator yet so you if you install your mani/decat before you get one and your hitting fuel cut, might be worth in getting one of those cheap ebay 'manual boost controllers' that sit on the vacuum line to decrease it etc, Havent used on my self but thought it might be handy as a temporary fix untill a adjustable actuator pops up mate Quote
lukEp Posted February 1, 2010 Posted February 1, 2010 fitting the fmic will lower the boost slightly so prob even it self out Quote
chr15_7_t_ Posted February 1, 2010 Author Posted February 1, 2010 only things im waiting on to be fitted is the mani,decat and port the wastegate .dont think il need to worry about fuel cut right now though...when i took my car out earlier it wasnt holding boost.. goes upto 11psi on my gauge and gradulay drops down to about 8psi when u keep the foot down lol Quote
lukEp Posted February 1, 2010 Posted February 1, 2010 thats the standard shitty toyota actuator there wank! Quote
chr15_7_t_ Posted February 1, 2010 Author Posted February 1, 2010 will that be casuing me to loose boost? Quote
DavidAshton Posted February 1, 2010 Posted February 1, 2010 Yes it will,Get an adjustable actuator, there is not much point putting the above on really if you cant tune the boost. Quote
chr15_7_t_ Posted February 1, 2010 Author Posted February 1, 2010 ive posted a thread up in the wanted section for one Quote
silverglanza Posted February 1, 2010 Posted February 1, 2010 mines 11psi hold fine standered actuator Quote
chr15_7_t_ Posted February 1, 2010 Author Posted February 1, 2010 mine was fine...past week it seems to be loosing more boost Quote
