nutnut Posted February 1, 2010 Share Posted February 1, 2010 Removed the air filter box & some pipes Fitted a cone filter & chrome pipewould i need to fit the sensor into the pipe ?On the original pipe the sensor was on the outside of the pipe !at the top left bit.Since i fitted my cone filter the car's drinking fuel like theres no tomorrow.at a guess with the sensor pushed aside the air intake is not working as it should be. Quote Link to post Share on other sites
Starlet__SR Posted February 1, 2010 Share Posted February 1, 2010 nutnut said: Removed the air filter box & some pipes Fitted a cone filter & chrome pipewould i need to fit the sensor into the pipe ?On the original pipe the sensor was on the outside of the pipe !at the top left bit.Since i fitted my cone filter the car's drinking fuel like theres no tomorrow.at a guess with the sensor pushed aside the air intake is not working as it should be.It'll be the air temp sensor sending an improper reading, you need to find some way of incorporating it into your intake pipe,Damien Quote Link to post Share on other sites
wssoR Posted February 1, 2010 Share Posted February 1, 2010 mine was drinking fuel when i left my sensor out but i cut a hole in the pipe between the filter and the mani and stuck it in there sorted it right out Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 Thank you guys Will get this sorted as soon as.Like in the next 10 mins once i made a coffee Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 Took the sensor out of the carHow would i fit it to my chrome pipe ? Quote Link to post Share on other sites
Jae-Glanza Posted February 1, 2010 Share Posted February 1, 2010 I've just relocated my air filter to behind the grill, so my 'sensor' is just in around the engine bay also! After seeing this thread i did a little search and most of the chaps on here have tucked there's up in the engine bay saying it doesn't do anything anyway! So i'm just going to make sure mines tucked up nicely not in the way and leave it.So stick the kettle back on and save your self some time mate, Fitting that to an alloy pipe is going to be a pain in your arse! =] Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 Jae-Glanza said: I've just relocated my air filter to behind the grill, so my 'sensor' is just in around the engine bay also! After seeing this thread i did a little search and most of the chaps on here have tucked there's up in the engine bay saying it doesn't do anything anyway! So i'm just going to make sure mines tucked up nicely not in the way and leave it.So stick the kettle back on and save your self some time mate, Fitting that to an alloy pipe is going to be a pain in your arse! =]Cheers mate Still drinking the last one. Quote Link to post Share on other sites
LukeSR Posted February 1, 2010 Share Posted February 1, 2010 Could do with a coffee... mmm.. Quote Link to post Share on other sites
wssoR Posted February 1, 2010 Share Posted February 1, 2010 Jae-Glanza said: I've just relocated my air filter to behind the grill, so my 'sensor' is just in around the engine bay also! After seeing this thread i did a little search and most of the chaps on here have tucked there's up in the engine bay saying it doesn't do anything anyway! So i'm just going to make sure mines tucked up nicely not in the way and leave it.So stick the kettle back on and save your self some time mate, Fitting that to an alloy pipe is going to be a pain in your arse! =]its not that difficult, just as long as youve got a drill and a fairly thick drill bit its a piece of cake LukeSR said: Could do with a coffee... mmm..coffee is disgusting by the way Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 Puzzled on why its drinking too much fuel ! Quote Link to post Share on other sites
Jae-Glanza Posted February 1, 2010 Share Posted February 1, 2010 I know i didnt mean it was a hard job, i just meant it's pointless IF it's not really doing anything =] Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 So which part do i need to put into the pipe ? Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 That sensor, is not a sensor! its a perge valve for the charcoal filter which basicly stops the fumes from the fuel tank going to atmosfear its not important and it wont make you use more fuel. I binned my charcoal filter as it wasnt working. Basicly causing a vacuum in my fuel tank, when i went to open the filler cap loads of air sucked in! Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 cheers guys.Time for a coffee then ! Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 its the n/a which have a air temp sensor there the turbos have it on the mani Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 dont leave the pipes disconnected in the engine bay block them off or plug the valve back in, if you leave it disconected it will cause problems nutnut said: So which part do i need to put into the pipe ? Quote Link to post Share on other sites
wssoR Posted February 1, 2010 Share Posted February 1, 2010 lukEp said: That sensor, is not a sensor! its a perge valve for the charcoal filter which basicly stops the fumes from the fuel tank going to atmosfear its not important and it wont make you use more fuel. I binned my charcoal filter as it wasnt working. Basicly causing a vacuum in my fuel tank, when i went to open the filler cap loads of air sucked in!what exactly does it mean when air is sucked in when you take filler cap off because mine started doing it and dont know what to do Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 Plugged it back in & tied it up out the way.If thats not the air intake sensor Where is the intake sensor ?When i open my fuel filler cap i get the sucking noise ? Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 it means the purge valve isnt working or the charcoal filter is blocked its a black plastic cylinder onthe bulk head on the passengers side under the bonnet about the size of a tin of beans just disconnect the bigger pipe that comes from under the car as there are two and it will stop vacuuming. Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 intake temp sensor it in the front of the inlet mani i'll geta pic later to point it out it more on the driver side Quote Link to post Share on other sites
nutnut Posted February 1, 2010 Author Share Posted February 1, 2010 lukEp said: it means the purge valve isnt working or the charcoal filter is blocked its a black plastic cylinder onthe bulk head on the passengers side under the bonnet about the size of a tin of beans just disconnect the bigger pipe that comes from under the car as there are two and it will stop vacuuming.When you disconnect it Do you block of the pipe ? Quote Link to post Share on other sites
Jae-Glanza Posted February 1, 2010 Share Posted February 1, 2010 Assuming were talking about petrol filler caps, mine also sounds like i'm opening a fizzy bottle of pop when i unscrew it, surely not all of our charcoal sensors job's are broken? ;o Quote Link to post Share on other sites
micky boy Posted February 1, 2010 Share Posted February 1, 2010 luke is spot on also Jae every fuel tank builds up pressure as it starts to get emty so you will get some air comeing out so it dosent meen your sensor is fucked Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 the purge valve is there to open the charcoal filter to suck the vapore into the inlet and to get burn so it not released into the air if your tank sucks in air when you open it it means it not venting something is wrong the only way the air is suposed to vent is through that filter so its got to be the valve is faulty or the filter is blocked. Quote Link to post Share on other sites
lukEp Posted February 1, 2010 Share Posted February 1, 2010 nutnut said: When you disconnect it Do you block of the pipe ? no it needs to vent to air or it will cause a vacuum in the tank again Quote Link to post Share on other sites
