dale10ellis10 Posted February 10, 2010 Posted February 10, 2010 As above, just got a hybrid off enzo and my airfilter relocation kit bend is a bit naff and i want a blue one to replace it, so i was just wondering if anyone has a link or a website where i can order the correct size hose to attach the turbo? also is it a exact 90 degree bend i need?Cheers Dale. Quote
Russleh Posted February 10, 2010 Posted February 10, 2010 youl get cheap pipes off ebay mate just have a look theres loads. think its 57mm your looking for. someone correct me if im wrong. if ya want some samco bits ya can get them off deamon tweeks but be warned they didnt tell me that they only get the part if from samco when it is ordered by you so when i got mine i waited about a month for it. Quote
dale10ellis10 Posted February 10, 2010 Author Posted February 10, 2010 Cheers guys ^^ is 57mm the size of the hybrid inlet or the standard ct9 because isnt the hybrid bigger correct me if im wrong?Dale. Quote
micky boy Posted February 10, 2010 Posted February 10, 2010 yeh the hybrid is bigger dale,Im not to sure the size on the hybrid but i know its about 40mm on the stock ct9 Quote
dale10ellis10 Posted February 10, 2010 Author Posted February 10, 2010 yeh the hybrid is bigger dale,Im not to sure the size on the hybrid but i know its about 40mm on the stock ct9cheers man :surrender: Quote
micky boy Posted February 10, 2010 Posted February 10, 2010 No bother mate i've just been in enzo's shop and had a look at the ct9hybrid and it says the inlet is 55mm so add another 2mm give or take. it will be 57mm like russleh saidhere is the link so you can check it out for you self buddy http://www.ukstarletclub.com/forums/index....w_item&id=1 Quote
dale10ellis10 Posted February 10, 2010 Author Posted February 10, 2010 No bother mate i've just been in enzo's shop and had a look at the ct9hybrid and it says the inlet is 55mm so add another 2mm give or take. it will be 57mm like russleh saidhere is the link so you can check it out for you self buddy http://www.ukstarletclub.com/forums/index....w_item&id=1Thanks! just read that aswell when you posted lol ..been on a few websites and theres so many lenths and that to choose from aswell ;) ..be ideal if someone had a link too one theyve bought and used themselfs but yano :surrender: Dale. Quote
micky boy Posted February 10, 2010 Posted February 10, 2010 found this on ebay http://cgi.ebay.co.uk/REDUCING-ELBOW-90-DE...4371737ff3e1c35give me 2min and i,ll find you a pipe to go this it lol Quote
dale10ellis10 Posted February 10, 2010 Author Posted February 10, 2010 Thats the boy ^^ :surrender: .. ill make a few definate mesurements tomoro when its light and ill get it orderd. thanks micky!Dale. Quote
micky boy Posted February 10, 2010 Posted February 10, 2010 Lol not a problem mate thats what we are here for i've also found a alloy pipe for you.. You might have to chop abit off to get it to fit spot on. it worked for me so it should you :surrender: this pipe is 50mm so its 1mm less then the silicon pipehttp://cgi.ebay.co.uk/Alloy-Bend-90-Degree...=item3efa39da96 Quote
