joel_ep91 Posted February 13, 2010 Posted February 13, 2010 ok im just woundering what the main signs are if your piston rings have gonethanks joel Quote
Kennedy Posted February 13, 2010 Posted February 13, 2010 Doesnt the engine start to tap n sound really bad? Quote
joel_ep91 Posted February 13, 2010 Author Posted February 13, 2010 i have no idea im just looking to know what to look out for so i can tell if it ever happens to me Quote
micky boy Posted February 13, 2010 Posted February 13, 2010 Have you got lots of oil comeing out of the cam cover breather? Quote
joel_ep91 Posted February 13, 2010 Author Posted February 13, 2010 Have you got lots of oil comeing out of the cam cover breather?no doesnt seem to be any oil coming from that just seems to be like a mist/ vapor type stuff nothing oily Quote
Scott-EP Posted February 13, 2010 Posted February 13, 2010 Or alot of blue smoke coming from the exhaust Quote
Dan Evans Posted February 13, 2010 Posted February 13, 2010 im in the middle of doing mine mate.Basicly mine was pushing oil through the rocker cover breathers, and it started sounding like a subaru slightly, wasnt missfiring but it didnt sound right, however it was still drivable.Do a compression test and see what comes up, I've taken my engine out today and im going to be doing the re-build shortly.if it is deffo the piston rings, Dont start the car up or anything just incase you damage something even more.Mine didnt smoke through the exhaust either Quote
Scott-EP Posted February 13, 2010 Posted February 13, 2010 We have alot of car's come down the garage and when piston rings have gone they almost always let out blue smoke from the exhaust like when we road test it and boot it abit Quote
micky boy Posted February 13, 2010 Posted February 13, 2010 Are you sure you are not on about valve stems gtr lol Quote
joel_ep91 Posted February 14, 2010 Author Posted February 14, 2010 what is blue smoke from if its not a silly question Quote
Dan Evans Posted February 14, 2010 Posted February 14, 2010 depends mate, could be your valve stem seals Quote
joel_ep91 Posted February 14, 2010 Author Posted February 14, 2010 depends mate, could be your valve stem sealsmine is a n/a. and i dont know how it would be valve stems they were done in it not long ago.another question is there any oil channesl in a turbo head that wouldnt be in a n/a head gasket and block? Quote
Dan Evans Posted February 14, 2010 Posted February 14, 2010 not too sure on that one mate, I've never had an N/A sorry. Quote
joel_ep91 Posted February 14, 2010 Author Posted February 14, 2010 not too sure on that one mate, I've never had an N/A sorry.ok thank you very much for you help dan very greatful Quote
Ryan-11 Posted February 14, 2010 Posted February 14, 2010 when piston rings/pistons when on mine i had oil blowing out the dump valve when it dumped and the engine was breathing heavy, oil comming out off the rocker cover breathers Quote
Scott-EP Posted February 14, 2010 Posted February 14, 2010 i know valve stem oil seals make the car smoke through the exhaust but we have had car's come into the garage were they have been smoking and we have taken the engine apart as the compression was very low and found the piston rings were in a shit state replaced them and solved the smoking and compression problems only ever done them on a N/A I cannot see how fucked piston rings couldn't give off a blue smoke from the exhaust, Because if oil is getting into the cylinder bores it is going to burn it thus causing blue smoke out of the exhaust, Sometimes when you change plugs on older car's they have oil around the recesses were the plugs sit, when you remove the plug it runs down into the cylinder and when you start the car up it smokes very heavily until it has burnt the oil off A mate of my old mans, his piston rings went on his car and the car was smoking really bad under heavy accelerationI'm not saying it's more common to have this happen then to have Oil come pissing out the Breather as i know that the obvious sign of piston ring damage is to have oil piss out of the rocker cover breather, But it can get up into the cylinder and burn off causing the car to smoke, Quote
Idrees Posted February 14, 2010 Posted February 14, 2010 I think I slightly damaged a piston ring.. Quote
Scott-EP Posted February 14, 2010 Posted February 14, 2010 Thats what you call a job well done! Quote
Ryan-11 Posted February 14, 2010 Posted February 14, 2010 also mines smoked under heavy acceleration too Quote
Danturbo4311 Posted February 14, 2010 Posted February 14, 2010 cylinder leakage tester or Compression test will tell you if its rings as others have said, with a compression test once you get the results put a spoonfull of oil down the low cylinders & repeat the test to see if compression raises. on our engines its normally the ringlands (between the rings) which crack. The symptoms of ring failure can vary depending on condition of the other rings & what ring has failed. Quote
Dean @RW-Developments Posted February 14, 2010 Posted February 14, 2010 idrees pic brings back memories lol and mine also smoked really bad to the point i couldnt see traffic behind me! Quote
Nick@TD.co.uk Posted February 18, 2010 Posted February 18, 2010 It tends to be the ringlands that break up on the starlet pistons, as said you will see oil coming from the rocker cover breather and also the dump valve sometimes.Sounding like a subuaru is part of it as well but once you do a compression test you will find the problem cylinder(s) if anyone is in doubt just drop us a message or call or even pop down with the car and we will check it out for you.Kind Regards,Nick JonesTuning Developments LTDWorkshop Landline - 01925 822266TuningDevelopments@Hotmail.comwww.TuningDevelopments.co.uk Quote
ForresGlanza Posted February 18, 2010 Posted February 18, 2010 This thread has worried me now lol, my rocker cover breather filter has a lot of oil in it and my car sounds really deep. bit like a scooby. I just thought it was my exhaust Quote
