kevink Posted February 22, 2010 Posted February 22, 2010 Hi guys,this is a strange thing maybe, but since i bought the car the interior light isn't working.Changed the bulb but still no light. bought a ledthingy a while ago and fitted that, to my suprise it worked but was giving only a TINY bit of light.suddenly last week late in the night i opened the cardoor and is was really bright!!(no not drunk) checked it out and it was the interior light indeed. worked like a charm for a couple of days and then suddenly now its back to the dull light again.it must be a lose wire or something, anybody had the same experience or could point out some wires i should check?i don't think the fuse has blown as a ledlight works, prob a normal bulb doesn't work cause there is not enough electricity running through it.any ideas/tips? Quote
lukEp Posted February 22, 2010 Posted February 22, 2010 wd40 under the rubber cover on the drivers side door switch problem solved. Quote
kevink Posted February 24, 2010 Author Posted February 24, 2010 Hi Luke,thing is the led-lights do light up but very weak, so it does register when door is opened.could it be the signal is to weak and spraying wd40 would solve it? Quote
lukEp Posted February 24, 2010 Posted February 24, 2010 the door swich sticks if its only just sticking the led might come on dim worth a try if its not that which mine was theres a box under the dash which controls the light also is somthing to so with the beeper when the key is in ign and the door is open if you put you key in the ign and open door and it dont beep id say swicth Quote
vit Posted February 24, 2010 Posted February 24, 2010 had the same thing on mine ,check the light its self,the switch where u "on-door-off" and earth ... Quote
Blair Posted February 24, 2010 Posted February 24, 2010 ^^as above^^poor earthing or wotnot - sounds like too much resistance intermittently mate Quote
BenV Posted February 24, 2010 Posted February 24, 2010 Pritty sure this is a common fault on all v's bud. Mines never worked lol Quote
kevink Posted February 24, 2010 Author Posted February 24, 2010 will get on it asap, let you guys know what it is if i find the prob. Quote
garo Posted March 10, 2010 Posted March 10, 2010 I have this problem too! Can be annoying, i bent the metal contacts between the bulb closer togetherseems to have sorted it for now. Quote
The_Notorious_C_A_T Posted March 10, 2010 Posted March 10, 2010 I did all that, and my bulb never worked. What sorted it was re punching the rivits on the plastic bit and it worked as I buzzed it and got voltage on the connector itself so it was the bulb holder itself.If you buzz the plug that goes to the light bit in the roof will give you an idea if it's the bulb holding bit itself or the switch. Although I had to wd the door switches as well as they where filthy as well. Quote
