Russleh Posted March 3, 2010 Share Posted March 3, 2010 gonna be picking up a bottom end to rebuild this weekend. will be replacing the bearings on crank and rodsthrust washerspiston rings and the crank needs a regrind. just wanna know 1. are the bolts for the rods and crank ok to use again ? 2. is there a special type of oil to use for initially lubing up the bearings or will engine oil be ok ? 3. common question but i wanna be 100%. 99% is not enough. all 4efte bottom ends the same ? would be crap to spent time n money on this for it not to fit lol. 4. just thought of another. after a crank regrind is all still fine to use standard shells ? thats all i cn come up with for now Russell Quote Link to post Share on other sites
ste91 Posted March 3, 2010 Share Posted March 3, 2010 gonna be picking up a bottom end to rebuild this weekend. will be replacing the bearings on crank and rodsthrust washerspiston rings and the crank needs a regrind. just wanna know 1. are the bolts for the rods and crank ok to use again ? Not sure, better to get new ones I expect.2. is there a special type of oil to use for initially lubing up the bearings or will engine oil be ok ? Yes, assembly lube.3. common question but i wanna be 100%. 99% is not enough. all 4efte bottom ends the same ? would be crap to spent time n money on this for it not to fit lol. As far as I know they are all the same apart from later Glanzas having lighter rods but that's insignificant.4. just thought of another. after a crank regrind is all still fine to use standard shells ? You will need to check the tolerances, most likely need different ones. thats all i cn come up with for now Russell Quote Link to post Share on other sites
llawgoch Posted March 3, 2010 Share Posted March 3, 2010 you will need undersize bearings if your crank is getting reground. the place thats regrinding it will tell you how much theyv took off and they should supply the correct bearings to suit. Quote Link to post Share on other sites
Russleh Posted March 3, 2010 Author Share Posted March 3, 2010 cool as long as they can let me know what ones ill need should be dandy. are the standard bolts expensive do ya know. thanks for your help so far guys. Quote Link to post Share on other sites
rorenapier Posted March 4, 2010 Share Posted March 4, 2010 just wanna know 1. are the bolts for the rods and crank ok to use again ? 2. is there a special type of oil to use for initially lubing up the bearings or will engine oil be ok ? 3. common question but i wanna be 100%. 99% is not enough. all 4efte bottom ends the same ? would be crap to spent time n money on this for it not to fit lol. 4. just thought of another. after a crank regrind is all still fine to use standard shells ? thats all i cn come up with for now Russell1. Bolts are fine to re-use on the crank and the nuts can be re-used on the rods. Make sure the rods are in good condition before putting anything back together.2. Assembly lube, or engine oil will do the job just fine.3. All 4e motors share the same block. No fitment issues.4. If the crank needs ground, the machine shop will be able to supply bearings to suit. This should also include thrust washers. Quote Link to post Share on other sites
Russleh Posted March 4, 2010 Author Share Posted March 4, 2010 thanks for that info dude. im assuming when checking rods , not bent is basically what im looking for Quote Link to post Share on other sites
rorenapier Posted March 4, 2010 Share Posted March 4, 2010 Yep and if the bearings have let go in a big way, the rod may be no use if it has been excessivley scored. Quote Link to post Share on other sites
