chriswoodfto Posted March 12, 2010 Posted March 12, 2010 hey, having decided i love the glanza i think im gona look at forging it so its bulletproof, just wondered what i would need to buy to do the job. or if itd just be cheaper to get tm developments to it, id be wanting to replace everything, water pumps etc etc. but i cant find a definitive answer from searching. the plan i had was to start and pic up the bits slowly now to spread out the cost and to have all the bits in say a year because im doing 10.000miles a year at mo, but ina year or so ill be living back near work so wouldnt be putting rediculous miles on the car. Quote
ste91 Posted March 12, 2010 Posted March 12, 2010 It's the same as any other rebuild but obviously you use forged pistons and rods instead of cast items. Quote
Russleh Posted March 12, 2010 Posted March 12, 2010 basically thats it what ste said. answered your own question kinda say u want to replace everything so buy everything. will end up quite costly to chang everything tho. ov added some of it up because thats what i want to do and it will shock ya. Quote
riko666 Posted March 12, 2010 Posted March 12, 2010 It's a grossly misused term, as the engine itself isn't actually forged at all (yeah, it annoys me), but as Ste said Quote
chriswoodfto Posted March 12, 2010 Author Posted March 12, 2010 thort there was more to it than just rods and pistons. wast the other bits recomended for a normal forged engine? by that i meen like the water pump etc? Quote
ktl Posted March 12, 2010 Posted March 12, 2010 Basically its just the pistons and the rods. Then while you do that you replace everything including waterpump,oil pump, oil switch, headgasket SET! which include seals,gaskets. Quote
chriswoodfto Posted March 12, 2010 Author Posted March 12, 2010 sweet, thats the info i was after, would you recomend gettting anything done with the block at all whilst its out? Quote
ktl Posted March 12, 2010 Posted March 12, 2010 of course. If your going forged or a standard rebuild you want to replace everything you can. I mean 100% on waterpump,oil pump, headgasket, all the seals,gasket,cambelt. Its vital because you will be peed off it if 1 fails on your new engine! Quote
Dan Evans Posted March 12, 2010 Posted March 12, 2010 Im doing one at the moment mate, heres the list...Parts,Wiesco 75mm pistonsScat forged rodsAthena 1.4mm headgasketARP Main boltsARP headboltsADL waterpumpToyota oil pump (maybe)new gaskets and oil sealsADL cam belt kitNew beltsMachine work;Block to be re-bored to take 75mm pistonsBlock honedhead skimmedlighten standard flywheelall chemically cleaned and re-painted.Crank to be polishedlater on, Head will be fully ported and polishedvalves re-seatedvalve stem seals replacedcleaned up.Seems quite alot seeing as im selling the engine next year lol Quote
chriswoodfto Posted March 12, 2010 Author Posted March 12, 2010 cheers dan, how much have you spent/going to spend i total do ya reckon? are all the pistons you can get 75mm or any that are correct size? Quote
Dan Evans Posted March 12, 2010 Posted March 12, 2010 74mm are standard size and traders sell the standard sizes mate, alot of people tend to go for 74.5mm, but i always go bigger the expensive parts are;pistons & rodsARP boltsheadgasket.The rest are cheapishil spend around 1200 for bits and machine work, not a cheap thing to do, but its worth it for sure Quote
Ryan-11 Posted March 12, 2010 Posted March 12, 2010 74mm pistons will fit without needing a rebore or u can get 74.5mm or 75mm witch will need a rebore Quote
chriswoodfto Posted March 12, 2010 Author Posted March 12, 2010 sound, cheers guys, i might drop you a few pms from time to time if thats ok dan? ill keep my eye out for the bit son the cheap then. if i just went with the 74mm, would i just need the head skimmed or still go for the block honed? (which is?)lol. Quote
Dave@TM-Developments.com Posted March 12, 2010 Posted March 12, 2010 Most importantly skim the block as well as they warp more than heads Quote
ktl Posted March 12, 2010 Posted March 12, 2010 Most importantly skim the block as well as they warp more than headswhat he said, mine did! Quote
