BAZ2CRAZY Posted March 14, 2010 Posted March 14, 2010 Im going to be fitting a screamer pipe...As i understand, my GT is pre 95 and shouldnt need a full emissions test..Will it pass with a screamer pipe?Mitch Quote
ForresGlanza Posted March 14, 2010 Posted March 14, 2010 i thought it was 93 or older didn't need a cat? Quote
The_Notorious_C_A_T Posted March 14, 2010 Posted March 14, 2010 screamer shouldn't make difference to emission really as it's venting boost, although might make the emissions less I suppose due to venting boost and not sending it through the engine, thus making the ecu fuel more.Although at the revs an mot test is done at I doubt a screamer would vent. Quote
BAZ2CRAZY Posted March 14, 2010 Author Posted March 14, 2010 Thats ok... im just debating with myself whether to leave the wepr system on untill i have an MOT..Or risk it and go for it with screamer. I just dont know how the MOT tester would react..Mitch Quote
BAZ2CRAZY Posted March 14, 2010 Author Posted March 14, 2010 Any body passed with a screamer?Mitch Quote
Meston Posted March 14, 2010 Posted March 14, 2010 You should only have to pass the basic idle emissions test and since the screamer pipe should only vent when on boost then you should pass with no worries. Quote
lukerobz Posted March 14, 2010 Posted March 14, 2010 mines a 95 i have a screamer and it pased ok Quote
BAZ2CRAZY Posted March 14, 2010 Author Posted March 14, 2010 Brilliant. Thanks for the replysMitch Quote
ste91 Posted March 14, 2010 Posted March 14, 2010 screamer shouldn't make difference to emission really as it's venting boost, although might make the emissions less I suppose due to venting boost and not sending it through the engine, thus making the ecu fuel more.Although at the revs an mot test is done at I doubt a screamer would vent.It's venting exhaust gas... Quote
Georgie Posted March 14, 2010 Posted March 14, 2010 just find someone to do u a dodgy mot and put it thru lol Quote
The_Notorious_C_A_T Posted March 14, 2010 Posted March 14, 2010 It's venting exhaust gas...totally correct there, I don't know why I put that tbh Quote
rorenapier Posted March 14, 2010 Posted March 14, 2010 Not at idle..It's venting exhaust gas... Quote
DavidAshton Posted March 14, 2010 Posted March 14, 2010 Im sure its technically an exhaust leak, but it should pass. Quote
