I'm halfway through a clutch change (that I started a few weeks ago! :D) and I'm having a nightmare trying to get the chuffing gearbox back on, I just can't seem to get the shaft into the clutch at all, I think it's just a case of not getting it lined up quite right.
So I was wondering if anyone had any tips of how to get it on, I've just got the box sitting on a jack then trying to lift it into position but can't get the shaft in, any suggestions on how to do it as I'm starting to get very frustrated with this!?
Lifting it from above :D are you heman or something lol
All i done when i fitted mine was made sure that the metal tabs on the gearbox lined up with the hole's on the Engine and give it a good kick an it fell on lol........All this was done from underneath
Lol no, more like Skeletor! :D
If it's that easy how am I having so much trouble! How did you get it in postion?
Did you File the splines down in the center of the Clutch plate ??
There quite blunt when you get them, if you file the corners of them down the shaft slides in alot easier :D
The bit i've circled in between the teeth :D
its got be the clutch not lined up pal if your having that much trouble
an is easy on your back with some help from above so they do the holding an you do the
twisting an widlein , make sure the box is not hangin low at the back
Lol i had a jack under the box just to help me out abit and me and my mate pulled it up....Im makeing it sound like it was easy but it took me and him a good few go's to get it on it was a right twat lol.
So basically if you dont have know on to give you a hand its going to be a nightmare :D
Just remember to line them metal tabs up on the box/engine or you will be there all day
I've not filed the teeth down but I'm going to check now how easily the plate goes onto the shaft,I also didn't use an allignment tool - I just did it by eye, I did it by eye previously (when the engine and box were both out) and the box fitted back on easily then, I am going to get a clutch allignment tool just incase though.
Even if the clutch wasn't alligned properly I think the shaft would still go partly on but I'm not getting anywhere at all, I think it is the the postioning of the box - it's just so bloody awkward and at the moment I am doing it just on my own.
