Need help with windows
i dont have electric windows but as far as i know
you have 3 or 4 of them twist n pop out screws.
Then you have to take the screw off behind the inside door handle.
you have have to pop out the bit where you hold to close your door n should be 2 screws there.
If thats all the screws you then pull the door card off.
Correct me if im wrong anyone.
