daveEP82 Posted May 1, 2010 Posted May 1, 2010 i rele havent looked that hard but where the hell is my ECU? ive got a 1994 ep82.. Quote
Asad Posted May 1, 2010 Posted May 1, 2010 Behind the glovebox, if you look under the dash when in the passenger footwell you`ll be able to see it......its the same for all EP`s Quote
ste91 Posted May 1, 2010 Posted May 1, 2010 It's not behind the glovebox in EP82's actually, or so I was told, it's to the left of the clutch pedal or something like that. Quote
Dave@TM-Developments.com Posted May 1, 2010 Posted May 1, 2010 EP82 is behind the centre console Quote
joel_ep91 Posted May 2, 2010 Posted May 2, 2010 my bros ep82 ecu is behind glovebox?why whould that be Quote
WallaceGlanza Posted May 2, 2010 Posted May 2, 2010 Behind the glovebox, if you look under the dash when in the passenger footwell you`ll be able to see it......its the same for all EP`sEven einstein know's they're not the same in all EP's. Quote
Steve GT Posted May 2, 2010 Posted May 2, 2010 EP82 is behind the centre console^^^ correctits behind the centre concole just above where the floor risesit might be in an ECU cover but to undoe it you need to take a 12mm (i think) bolt out of the bracket on the passenger footwell side then go to the drivers footwell and take out the 2 clip leads and a couple of screws then it will pull out on the passenger side matey Quote
daveEP82 Posted May 2, 2010 Author Posted May 2, 2010 ^^^ correctits behind the centre concole just above where the floor risesit might be in an ECU cover but to undoe it you need to take a 12mm (i think) bolt out of the bracket on the passenger footwell side then go to the drivers footwell and take out the 2 clip leads and a couple of screws then it will pull out on the passenger side mateycheers very muchly Quote
Asad Posted May 2, 2010 Posted May 2, 2010 lol, what i ment was if he takes the glovebox off he will be able to see it clearer unless its got the black cover on itchhheeeeshhh, bunch of women also wallace? care to explain what you ment by that remark? Quote
bucketep91 Posted May 3, 2010 Posted May 3, 2010 itas not behind the glove box tho asad, thats what he meant lol. its behind the radio on the ep82, taking the glove box out would be a waste of time Quote
WallaceGlanza Posted May 3, 2010 Posted May 3, 2010 lol, what i ment was if he takes the glovebox off he will be able to see it clearer unless its got the black cover on itchhheeeeshhh, bunch of women also wallace? care to explain what you ment by that remark?It's something called a joke since you have "smarter than einstien" in your sig. As said the ecu isn't behind the glove box on the ep82's. Quote
