Asad Posted June 9, 2010 Posted June 9, 2010 i think??All cars go thru the same basic test, if they pass this then thats it.......if it doesnt pass this within 2 1/2mins another cat test is done which is car specific thats where all the ball ache starts.Have a read second post, here Quote
Steve GT Posted June 9, 2010 Posted June 9, 2010 scoobs are different though asad. the import scoobs get matched to the UK spec scoobs on the vosa database unlike the fte starlets whick have no UK equivalent so the rules are different matey Quote
Asad Posted June 9, 2010 Posted June 9, 2010 The posted question was regarding a FTO, and the answer given was genericIf my understanding is right.....1) ALL cars go thru the BET test first if they pass the following thats it no more testingFast Idle (2500-3000rpm): CO no more than 0.3%, HC no more than 200 ppm, Lambda between 0.97 and 1.03 Normal Idle (450-1500rpm): CO no more than 0.5%2) if it failed the BET they go thru a full emissions test which is carried out 2 1/2 mins later:1st aug 1992 - 31 july 1994?on the database = (CAT) test using the stated requirmentsnot on the database = (non cat) CO can be no more than 3.5% and the HC and be no more than 1200ppm1st aug 1994 or newer? on the database = (CAT) test using the stated requirmentsnot on the database and is 1st aug 1994 - 31st july 1995 = (non cat) CO can be no more than 3.5% and the HC and be no more than 1200ppm not on the database and is 1995+ = (CAT) same as the BET requirementsMeaning all glanzas should be passing the BET Quote
Steve GT Posted June 10, 2010 Posted June 10, 2010 The posted question was regarding a FTO, and the answer given was genericFTO? im confused now the question was for a 97 glanza where did you get FTO from? Quote
Wantaglanz Posted June 10, 2010 Posted June 10, 2010 yeah it doesnt matter if its an import or not, if the uk has an equivilant spec model then the mot tester would just use that, other wise he would follow the diagram from that book,when i worked in a garage the immisions test machine we used had all the information on it, so you would put all the information of the car into the system such as the year make and model and it would decide the test for you, in this case it would require a basic cat test for the car as it wouldnt be on the database and is older than a M reg carso he has no argument really, if it was an older gt then yeah, no cat test needed, but if yours is a n plate then no, its the mot testers decision at the end of the day Quote
GlanzaKidB77 Posted June 10, 2010 Author Posted June 10, 2010 Got everything booked in except from this Handbrake situation... apparently my rear pass caliper has moved and thats why theres sum slack in my handbrake. Can anyone shed some light on this please? Quote
Guest ep82_girl Posted June 10, 2010 Posted June 10, 2010 i didnt even know calipers could move thought they were stuck there.my car dont have a decat (apparently its cause of her age) and she has never failed in emissionsxxx Quote
lukEp Posted June 10, 2010 Posted June 10, 2010 Been told if you bang some high octain fuel in it will lower the emitions plus some injector cleaner to clear the shit from the injectors "go figure" Quote
ryan lang Posted June 10, 2010 Posted June 10, 2010 my brother tried the injector stuff and petrol and took it for a good ragging 1st and it still failed the emissions, then he had to have a cat put in, but he can take it out and put the decat in then when mot time comes he can pop it back out and put the cat in Quote
GlanzaKidB77 Posted June 11, 2010 Author Posted June 11, 2010 Anyone know where i can grab a rear pass caliper frm? just the 1 tho? Thanks Quote
