stan_the_man Posted October 30, 2006 Posted October 30, 2006 Im going to try everything possible to get a good time at crail 1/4 mile on sunday.Has anyone ever used a fuel additive such as an octane booster?My SR is basically standard so im aiming for high 17'sPlans are:Fit JDM inlet manifold20litre jerry can of V-powerBottle of octane boosterSlick/semi-slick tyresDisconnect power steeringStrip interiorAny other ideas? Quote
paul w Posted October 30, 2006 Posted October 30, 2006 Octane booster is shite! Get some race fuel and leave the v power for the run home, if you wanna have a bit more power octane booster only raises the level by about 0.5RON so you gonna need alot of it to have any real effect! Just re-read your post,Trouble is you are running an SR so it's never gonna set a blistering time down the track,not sure how much effect race fuel would have in a N/A either.Don't fill the fuel tank up too much,fuel =weight. Quote
stan_the_man Posted October 30, 2006 Author Posted October 30, 2006 yeh i was just going to put a bit in at a time to keep weight downive not long had the car and im just interested to see what time i can get Quote
ben_j Posted October 30, 2006 Posted October 30, 2006 lose as much weight as possible is the very best thing to do... that and good tyresdo you have coilovers? Quote
Glanza_Ragger Posted October 30, 2006 Posted October 30, 2006 ditch interior. thats what i do everytime im on the strip. gain slightly better acceleration Quote
stan_the_man Posted October 30, 2006 Author Posted October 30, 2006 suspension it bog standardgonna put rear bags up to 40psi and front down to 10-15psi in an attempt to combat weight shiftingditching all bar the dash and 2 front seatsits like having my nova back again lol Quote
Sparky Posted October 30, 2006 Posted October 30, 2006 you've got the idea mate.... get rid of as much weight as possible and sort the traction out. Dont know if a decent panel filter would make much difference but hey they aint expensive, so its worth a try Dont forget to get some VIDEOS mate Quote
stan_the_man Posted October 30, 2006 Author Posted October 30, 2006 Ive got a K&N universla filter fitted but may go for standard airbox with K&N element instead.remove N/S headlamp too for better breathing Quote
Starbus Posted July 8, 2008 Posted July 8, 2008 suspension it bog standardgonna put rear bags up to 40psi and front down to 10-15psi in an attempt to combat weight shiftingditching all bar the dash and 2 front seatsits like having my nova back again lolYou might want to keep 1 seat in there to sit on You'd be better letting the tyres down in stages. 15psi with that much power you might bog down, Remember some slip is optimum. Quote
Driver Posted July 8, 2008 Posted July 8, 2008 You might want to keep 1 seat in there to sit on ;) You'd be better letting the tyres down in stages. 15psi with that much power you might bog down, Remember some slip is optimum.front seats are for cowards strip the lot out and sit on the flooryour going in a straight line small plyers instead of a steering wheel Quote
Lee_EP82 Posted July 8, 2008 Posted July 8, 2008 front seats are for cowards strip the lot out and sit on the flooryour going in a straight line small plyers instead of a steering wheel ;)Hes got the same idea as me.Make sure you have a shit before aswell, go down in your undies and some lightweight socks. Hair cut the day before should help if you don't make a good time. Next run you take your bumpers off lol I'm planning on taking a can of V-Power and dont fill my tank up and try to get there with nearly an empty tank then put some V-Power in to get me up the strip a couple of times. Quote
Driver Posted July 8, 2008 Posted July 8, 2008 Hes got the same idea as me.Make sure you have a shit before aswell, go down in your undies and some lightweight socks. Hair cut the day before should help if you don't make a good time. ;) Next run you take your bumpers off lol I'm planning on taking a can of V-Power and dont fill my tank up and try to get there with nearly an empty tank then put some V-Power in to get me up the strip a couple of times.i was thinking bout this with fueland keep bumpers on for aerodynamics, no wind resistance on your boot lid though Quote
Lee_EP82 Posted July 8, 2008 Posted July 8, 2008 I'd just strap a parachute to the back lift peoples hopes lol. Then whack out your 17 second 1/4 mile hehe ;) Quote
Callan Posted July 11, 2008 Posted July 11, 2008 rise the back end 2 foot in the air,get some metal poles as front shocks,15psi of typre press.2 bar of boost,t88 turbo....there ya go Quote
Tintin_SR Posted July 11, 2008 Posted July 11, 2008 hate to tell you all bus stan is one of my best pals ans unfortunately his sr is a bit dad Quote
wg daz Posted August 2, 2009 Posted August 2, 2009 i ran low 17's in a standard corolla ae111(4efe) weighs a ton so if you cant run it in 17 then you need help Quote
