What is the problem with the Catch can now then ?
And you can buy one in Holland i think :)
Or i can buy one and send it to you ?
The discs i got of Ebay :(
The catch tank itself is spot on its just the bracket that holds it on keeps snapping :) its just flopping around in the engine bay at the minute.
  • 1 month later...
  • 5 months later...
So a couple of months have past..
Allote as been done and need to be done
I have orderd from Japan Reflet rear lights and got them in thanks to a Dutch friend
Then i got them in
As you see on the pics above at the rear window wiper the Tail is getting blue..
So i started to get it sprayed this is before painting
Also got a project of my own.. (of my pervious hobby carbon for scooters)
Bought some stuff again
Whiteline Pandhard Rod
Whiteline Anti lift kit
Hell Clutch Braidline
Racetech Oil feed
I bought a Exhaust a Tanabe.. seller said it will make noise so i looked at it..
And the Flex part was broken..
Got the Tip of and looked at the inside
New Flex Part..
New Demping plate that i made my self..
Drilled 1330 holes
Exhaust finished
Got myself a AEm Wideband
Nut in the Decat..
Have also a Fpr in with braidlines AN
Got a new Clutch.. Exedy Stage 1..
On the back of the Clutch box..
Got some other Wishbones..
And got some new Rims.. Rota Auto X with some damage..
As you see the Red lip is coming of.. but that's good because i don't like the red lip
So i was going wild with a Pass of the Gamma (store in holland)
Test fit..
One rims almost ready.. it's a chrome lip.. not white.. phone pics
And as last.. my daughter in my car
That was it for a this time :lol:
  • 3 months later...
Hello people..
Got some work done on the car again
Got some New Earl's Brake lines in
Installed them the same day
Got also a Whiteline Rear Adjustable Anti Roll Bar also already on the car..
Bought some Razo pedals of Jay
And Bought a AEM Tru Boostcontroller
And i Sanded the Rota rims some more..
But a red small ring i can't come with the Mouse Machine
Bought also a connectors for a Field Harness
Bought a Greddy Emanage Blue (sold it already and bought a Ultimate)
Polished the rims and finished it
Got the car up on one side.. and started the car in second gear and sand it then in till 600 waterproof and then Belgom ALU :D
Orderd some tires : Falken Ziex Ze912
And got them on the rims..
Got the Whiteline Anti-Lift kit on the car with the GTT wishbones.. but sometimes it makes a cracking sound..
So thinking of putting the old wishbones on of a Glanza is think they look smaller because the GTT Wishbones are very close to the Front sway bar :p Is that normal ???
And bought some Subaru front seats that will go in the Starlet :p
  • 3 months later...
Update :
I have done some things to the car again..
I got a Engine Damper in only without the top bracket.. so i orderd that with Jezza..
After a week or so i got the bracket in so i installed it..
I finally got my E-Manage Ultimate in.. only need to buy some lose parts..like (leads,map sensor and maybe another option)
Also got a JAM manifold.. i installed it and it makes a big differents in sound.. it's like a little subaru :D
I had a SS manifold..
Because i had the Subaru sound a little i tought of buyin Subaru seats.. and installed them right away..
I bought a Set of CJ Performance Aluminium pulleys..Not installed yet :p
I Got finally installed the Exedy Stage 1 Clutch with a Shimmed Flywheel(there is a kg off)
Don't have any pics of that :)
I did go to a Dyno meeting.. here in Holland.. With Dp Engineering that have a Dyno Pack :D
The result :
- 174bhp
- 151whp
- 235nm
I'm very happy with the result :D
But that was it for now..
The Car is standin on Winterwheels now :p
  • 3 months later...
Update 12-03-2012
I got rid of the Rota's wheels..
And bought some Weds Sport TC05
Got them all dirty :
I clean them up :
And got them on the Car :
Soon i will have my Quaife LSD in the gear box and then under the car
Greetings,
Jeroen
