Use wd40 to get the gule off :) ....NOTE!! if i was you i would get the hair dryer on it first befor you start pulling on it!!! If not you might pull the lacquer off
Another tip i have used before is to use dental floss and gently floss the badge off, leaving the sticky part, then a bit of heat and wd40 and its gone! :)
