Hi guys
well thinking about turbo's and need some advice
do i go gt-spec hybrid or td12. Im undecided and need some advice
im not forging but will be doing a fully rebuilt recon engine over the winter and need a new turbo to go with the fresh build.....not whats everyones reccomendations?
also anyone got a link to a price for the TD12's and whats needed to go with one (external wastegate/oil lines etc) I did get some info over text from geo but deleted them
opinions please :thumbsup:
you should be look at that kit kit steve IMO...
http://www.race-tech.net/index.php?main_pa...p;products_id=1
The Manifold is Stainless
The Screamer Pipe is Stainless
You'll Get More Power (full boost by 4k rpm so little slow spool)
You Get a Tial 38mm Wastegate!
and its £170 cheaper then a td12 kit...
and u saw Giggz's result at the MM RR day...
yeah you was on about that last night
had a look but if i had td04 id want to forge and go bigger power
racetech make the td12 kit for me, if you buy the parts individualy it will be a lot cheaper then that.
how long will the racetech kits be available? like is it a limited stock or could i buy 1 at any time?
PM ricky... think its on offer till end of august like it says on there..
:s dont understand... It thought things were cheaper if u buy em as a kit...?
personally i'd go gt spec. Cheaper for similar gains in my opinion on a non forge. Once my clutch is sorted i.ll post a new rr sheet up. Then u can see how they do. Otherwise go ct9 at 1.1.
