Josh@TunerLifestyle Posted August 4, 2010 Posted August 4, 2010 im looking at getting some hubcentric spacers to give my car abit of "poke" because as you all know they sit inside the archers moreso at the rear, i have coilovers and have 205/45/16 wheels, so what do you think would be the rite size to give my car its much needed poke cheersss josh Quote
whitetrash Posted August 4, 2010 Posted August 4, 2010 i was just about to look into this, my rears could use spacing for sure Quote
Glanza_cl Posted August 4, 2010 Posted August 4, 2010 personally i wouldn't push more then 20mm... puts quite alot of stress on the studs, i snapped a stud on my mr2 running 20mm spacers but the wheels i had where a bit ott for it.as long as you have the correct spigot rings and the wheel seats nicely and doesn't vibrate to much 20mm spacers would be fine Quote
durmz Posted August 4, 2010 Posted August 4, 2010 it all depends on the offset of ure current wheels tbh, if you have a low offset u wont need big ones if you have high offset u will need bigger, you basically need to measure the distance from your tire to your arch and get spacers to move it over how much you would like Quote
Josh@TunerLifestyle Posted August 4, 2010 Author Posted August 4, 2010 was thinking 20mm plus my arches have been rolled, il have a snoop when i get a chance as im "ment to be" working lol Quote
Josh@TunerLifestyle Posted August 4, 2010 Author Posted August 4, 2010 on the back gap between the tyre to arch is a wopping 40mm ouchh the front is 20mm tho, hmmm starlets are built wrong lol Quote
durmz Posted August 4, 2010 Posted August 4, 2010 fwd cars are supposed to have a wider front track to reduce understeer, thats why its like that Quote
Josh@TunerLifestyle Posted August 4, 2010 Author Posted August 4, 2010 learn something new every day so spose 20mm spacers all round would be ideal Quote
Liam_D Posted August 4, 2010 Posted August 4, 2010 Would also like to know what the best ones are to get as im looking at getting some in a month or so. I was Thinking 20mm allround to be honest. Quote
Craig_N Posted August 4, 2010 Posted August 4, 2010 I just won some on ebay with longer studs 20mm all round £36 BARGIN Quote
LukeSR Posted August 4, 2010 Posted August 4, 2010 I just won some on ebay with longer studs 20mm all round £36 BARGIN Damn you Quote
LukeSR Posted August 4, 2010 Posted August 4, 2010 You wont be doing that when i rape you at Japfest Quote
durmz Posted August 4, 2010 Posted August 4, 2010 Sounds good, that way u keep the difference in track the same, i need to get spacers soon i think, arches rolled and flared first though Quote
Josh@TunerLifestyle Posted August 4, 2010 Author Posted August 4, 2010 £36?! bladdy hell! i thaught they was more like 100 lol got a link for any more? Quote
Josh@TunerLifestyle Posted October 22, 2010 Author Posted October 22, 2010 bringing this back from the dead!after some but not sure where to get and if there the right ones,thinking 25 all round!I've got 205/45/16 45offset at front, 50 at rear on tein flex coilovers with arches rolled, think its possible? Quote
Josh@TunerLifestyle Posted October 23, 2010 Author Posted October 23, 2010 bump! wanting some of these soon Quote
SiCaln Posted October 25, 2010 Posted October 25, 2010 why not just get some h&r or ebay ones?!what do we have do to help u in that? Quote
Josh@TunerLifestyle Posted October 25, 2010 Author Posted October 25, 2010 just wanted to make sure that the centre bore and fitment was okay because they are not specified for starlets, i dont fancy spending loads of money to find they dont fit lol il have a look at them nowcheers josh Quote
SiCaln Posted October 25, 2010 Posted October 25, 2010 check for ones in the US that fit the Paseo and Tercel they will work Quote
