Socks Posted August 5, 2010 Posted August 5, 2010 hey chaps! bought a glanza gearbox this week w/cusco 1.5way LSD in it...the guy i bought it off told me to use some kind of special diff/gearbox oil...i usually just use decent off the shelf gearbox oil from my local motorstore?should i be using somthing special, obv i dont wana damage it cus they aint cheap!Cheersmatt. Quote
micky boy Posted August 5, 2010 Posted August 5, 2010 I've heard royal purples the one to use pm si (sicaln) he should be able to sort you out Quote
Socks Posted August 6, 2010 Author Posted August 6, 2010 wat weight do i need and how much will fill the box plz? Quote
micky boy Posted August 6, 2010 Posted August 6, 2010 Im not to sure to be honets..if you PM si he should be able to supply you with what you need hope that helps bud Link Royal Purplehttp://www.ukstarletclub.com/forums/index....ic=10101&hl= Quote
Russleh Posted August 6, 2010 Posted August 6, 2010 my box has a cusco diff in it and i use redline 75w90 ( cant remember what one as there are a few choices) and also a redline friction modifier. Quote
SiCaln Posted August 6, 2010 Posted August 6, 2010 75w90 is the stuff u can use with a helical lsd, if u have a mechanical clutch, u would need to add a friction modifier additive Quote
