Well basically one on the studs that you screw the rocker cover nuts on to has snapped at the top. I can't get another nut on to it so at the moment it has silicone on it because I have to use the car.
My question to you guys is can these studs be bought or are what could I do to fix it. Will try and get a picture up ASAP.
Hope you know which bit I'm on about.
if u take the rocker cover off the studs are part of the bolts that hold the cam into place so yeh ul be able to get them from toyota quite cheap. speak to gary. think its gbrmotorsport now . he can ge toyota parts.
  • 6 months later...
take a picture of the one you need and post it up, if it's the cam cap you need with the long stud on the top then i'll have one on my spare head. on the alluminium cap there will be a id mark on it like E5 or I3, something like that, let me know and i'll sort it for you fella.
  • 3 weeks later...
