Dannymo Posted August 17, 2010 Share Posted August 17, 2010 starting with an rx7 tmic what would be the best and most efficient way to reach that sort of power? ive all ready taken care of the handling and breaking so now its time to move on to power. my mods so far are straight through exhaust BOV iradium spark plugscheers Danny Quote Link to post Share on other sites
Josh@TunerLifestyle Posted August 17, 2010 Share Posted August 17, 2010 de-catported mani or a mild steel oneair filter relocationsome propper engine managementajustable acturator to turn boost upi think that will see that sort of power maby more Quote Link to post Share on other sites
Dannymo Posted August 17, 2010 Author Share Posted August 17, 2010 that sounds decent enough to me shouldnt burst the bank either! Quote Link to post Share on other sites
Josh@TunerLifestyle Posted August 17, 2010 Share Posted August 17, 2010 engine management will be the most expencivecan get a decat for about 120acturator 90so not that bad tbh Quote Link to post Share on other sites
ste91 Posted August 17, 2010 Share Posted August 17, 2010 You can get that sort of power @ 12psi on the CT9 but you will want to port the wastegate to reduce boost creep.As already mentioned, exhaust manifold and decat, air filter, adjustable actuator (turn it up to 11-12 psi, but remember fuel cut is at 12.5 psi so any bit of creep and you will be hitting it). It is possible to get 160ish bhp without touching the ECU but it's advisable to atleast get a piggyback such as Emanage Blue to make the most of it, and once you go past this point in power you'll need to upgrade the fuel management anyway so it's worth getting.Also if you were to upgrade the RX7 TMIC to a good FMIC you could turn the boost up to 1 bar and get around 180bhp on a good remap. Quote Link to post Share on other sites
bucketep91 Posted August 17, 2010 Share Posted August 17, 2010 bit off topic mate but where in glasgow u from? Quote Link to post Share on other sites
Dannymo Posted August 17, 2010 Author Share Posted August 17, 2010 bishopbriggs mate you? Quote Link to post Share on other sites
bucketep91 Posted August 17, 2010 Share Posted August 17, 2010 im from dennistoun mate, never seen u about. we all need to sort out a scottish meet soon thers loads of us now Quote Link to post Share on other sites
gtmuzz Posted August 17, 2010 Share Posted August 17, 2010 we all need to sort out a scottish meet soon thers loads of us nowYess we should! Quote Link to post Share on other sites
Dannymo Posted August 17, 2010 Author Share Posted August 17, 2010 sure there was a thread in the scottish section but it never happend! Quote Link to post Share on other sites
Dannymo Posted August 17, 2010 Author Share Posted August 17, 2010 what mods did you have in place other than the rx7 tmic ? Quote Link to post Share on other sites
RobSR Posted August 17, 2010 Share Posted August 17, 2010 You could hit that at .8 bar matey you wouldn't need to touch the mani, just put a decat on there and an adjustable actuator and a Safc or similar to trim the fuelling. If you get a 2" decat it would hardly creep or even not creep atal aswell so you wouldn't have to worry about porting the turbo.In an ideal world for you tho you'd want this ontop of what you've got at the minManiDecatFmicRelocated filterAdjustable actuatorManagement (emb or something) Quote Link to post Share on other sites
Quite97 Posted August 17, 2010 Share Posted August 17, 2010 Hit 161 bhp and 184Nm the last time I was on the rolling road.Only fit a filterrelocation with K&N-filter, ARC-TMIC, zisco-mainfold and a custommade stainlesssteel exaust (2,5").Everything else is stock on the engine, also the actuator or the boost is untoucht. Quote Link to post Share on other sites
Dannymo Posted August 17, 2010 Author Share Posted August 17, 2010 thanks for the help people appreciate it Quote Link to post Share on other sites
