gtmuzz Posted August 26, 2010 Posted August 26, 2010 As title says whats the best way to go about it! I tried and failed and now have nothing!!!I know it shouldnt be hard, im just a virgin to bleeding clutches Cheers Quote
rorenapier Posted August 26, 2010 Posted August 26, 2010 Same principal as bleeding brakes.Always worked for me. Quote
gtmuzz Posted August 26, 2010 Author Posted August 26, 2010 thats what i thought and it never worked Quote
Russleh Posted August 26, 2010 Posted August 26, 2010 yeh just allways with the pumping and hold it down and get someone to bleed in and repeat as many times as ya see fit. Quote
gtmuzz Posted August 26, 2010 Author Posted August 26, 2010 yeh just allways with the pumping and hold it down and get someone to bleed in and repeat as many times as ya see fit.this is exactlt what i was down but the slave doesnt seem to be taking fluid from the reservoir, just run out of fluid somehow, so there was no more fluid to bleed an no pedal at all! Quote
Russleh Posted August 26, 2010 Posted August 26, 2010 hmm defo check for a leak somewhere. maybe in the flexy bit. if it was completely empty u might just need to add more and continue. really theres nowhere it can go unless theres a break in the pipe Quote
gtmuzz Posted August 26, 2010 Author Posted August 26, 2010 hmm defo check for a leak somewhere. maybe in the flexy bit. if it was completely empty u might just need to add more and continue. really theres nowhere it can go unless theres a break in the pipeCheers bud i'll have a look when its light out, couldnt see any breaks but it was gettin dark Quote
Russleh Posted August 26, 2010 Posted August 26, 2010 yeh i know the feelin. just finished strippin the interior of my car and by the time i put the tools away i couldnt see all the bits i took out. think i got them all tho haha Quote
DavidAshton Posted August 26, 2010 Posted August 26, 2010 My guess is you filling the brake reservoir not the clutch reservoir.Look behind the brake fluid reservoir to the right there is an even smaller pot for the clutch fluid. Are you filling that one? Quote
Russleh Posted August 26, 2010 Posted August 26, 2010 lol never thought of that i hope thats what uv done for coming value hah Quote
gtmuzz Posted August 26, 2010 Author Posted August 26, 2010 Done hahaha still some air in the system but a couple more bleeds tomorrow will sort that now that there is fluid in itCheers lads Quote
ktl Posted August 27, 2010 Posted August 27, 2010 i just whack a hose end of the nipple, put it into a cup with abit of fluid in there, and open the nipple. will let it out it self. Quote
