right guys
got a greddy rear strut brace recently that has two holes on each base part but my glanza has four threads?
do i cut two of the threads off or how exactly can i fit this?
thanks for any help guys
well man if it was made for the car there should be no need to cut and drill. i highly doubt cusco has in their instruction that this is what has to be done.
as said swap ends and if that doesnt work i would get my money back. the brace has to be square across otherewise the bolts will be taking the strain and cause problems. thats alot of effort. aswell if you drill it out its not going to be worth the money if you ever go to sell it.
is there a difference between na and glanza top mount parts?
as it came of a na
well ive heard the rear strut braces off standard v's wont fit on n/a's for some reason not sure why though mate.
as it came of a na
by the looks of things man i would say so. im sure you could flog it for a new one?
The rear 3 point toyota optional extra one doesnt fit N/As and Mk1 1 GTs as theres no place to bolt it at the bottom.......the brace you have should fit 100% be it 2 bolts or 4 bolts if not id go knock on the sellers door.
As above i very much doubt cusco or anyone got the manufacture process wrong
the cusco brace does have the 4 holes unlike the greedy's which i never understood as every turbo I've seen has 4 and uk n/a has 2. Was the greedy only designed for the n/a's then? which would be quite silly lol
A good indication would be to look back at Whitelines braces as I'm pretty sure there was the 2 bolt problem back then as well and people had to drill. Hardcore EP91
Cusco is always 100% for rear brace fitment but the plastic mount covers either have to be trimmed or removed.
Joz
What do the other 2 studs/bolts do that are not attahed to the rear shock ?
i think they were added for the oem optional rear strut brace. well thats what i always thought anyways..
