madmax_926 Posted October 20, 2010 Posted October 20, 2010 had car jacked up today started it and wheels rotated same way wen off the ground wot does this mean and also when stopped one wheel Quote
micky boy Posted October 21, 2010 Posted October 21, 2010 If you have got OEM LSD then both drive shafts will be the same lenth..if one drive shaft is longer than the other (Drivers side) then you dont have LSD. Quote
ToyotaTech15 Posted October 21, 2010 Posted October 21, 2010 If you turn one wheel andvthe opposite side turn the same way at the same speed you have a LSD, of the opposite wheel turns on the opposite direction to the wheel you are turning it's still standard.Gary Quote
rorenapier Posted October 21, 2010 Posted October 21, 2010 Unless you have an aftermarket LSD..If you have got OEM LSD then both drive shafts will be the same lenth..if one drive shaft is longer than the other (Drivers side) then you dont have LSD.Remember the worm wheel mechanical diffs will still spin in the opposite directions, only plated diffs and "paul" diffs will spin the same way Quote
madmax_926 Posted October 21, 2010 Author Posted October 21, 2010 ok still bit confused lol im positive it odnt have lsd really cause in wet it just spins and pulls to one side Quote
Amjad Posted October 21, 2010 Posted October 21, 2010 What are your tyres like? lolWouldn't it tend to spin in the wet anyway, that's more down to the tyres I guess? Quote
madmax_926 Posted October 21, 2010 Author Posted October 21, 2010 What are your tyres like? lolWouldn't it tend to spin in the wet anyway, that's more down to the tyres I guess?they r toyo proxes t1rs and when it spins in the wet it just pulls to one side Quote
Amjad Posted October 21, 2010 Posted October 21, 2010 Hmm I've got new T1Rs and broken traction in the dry in the NA lol Quote
micky boy Posted October 22, 2010 Posted October 22, 2010 ok still bit confused lol im positive it odnt have lsd really cause in wet it just spins and pulls to one side9% out of 10 if you dont have LSD the P side shaft will spin first because its the shortest shaft! so it dose sound like you dont have LSD with it pulling to one side, im gessing its pulling to the left? Quote
madmax_926 Posted October 22, 2010 Author Posted October 22, 2010 yup goes to the left like a bitch lol lmao Quote
