Steve GT Posted December 10, 2010 Posted December 10, 2010 well I've got a new mani, decat and turbo and i was wondering where i could get new nuts bolts washers etc for themi dont have the old ones anymore so cant just go get new ones by comparing them and to be honest cant be bothered getting hold of some then changing them if there wrong etcso does anyone know if i can just buy some that will 100% fit the mani, turbo decat etcmight be worth seeing if Dean at RW developments fancies making up a kit as im sure people would be interested in this just like his engine bay dress up kitany info would be great guys and also il PM dean now see if he's interested Quote
Socks Posted December 10, 2010 Posted December 10, 2010 i cant see people being interested as a kit as people dont tend to need them cus they dont loose them in first place...just go to a nuts & bolts supplier and ask for some... tis wat id do! Quote
micky boy Posted December 10, 2010 Posted December 10, 2010 Is this what you are after?http://www.camskill.co.uk/products.php?plid=m19b0s1303p62068 Quote
Steve GT Posted December 10, 2010 Author Posted December 10, 2010 as i said dont have the old bolts and cant be arsed to find and calculate all lengths etc would be easier if someone made a kit for themjust seeing if theres any interest in them. would be good for people who have old as hell rusty bolts to to replae them with nice new ones Quote
Steve GT Posted December 10, 2010 Author Posted December 10, 2010 Is this what you are after?http://www.camskill.co.uk/products.php?plid=m19b0s1303p62068nice one mickey that helps. any turbo to de-cat and manifold to turbo bolts anywherewould still be good to see if any traders etc are interested in this would probably be a lot cheaper than camskill and other big companies can offer Quote
DavidAshton Posted December 10, 2010 Posted December 10, 2010 Get them straight from Toyota, saves pissing about. Quote
DavidAshton Posted December 10, 2010 Posted December 10, 2010 Becarful what you get becasue there double threaded studs rather than bolts for the manifold and decat. Quote
GTnomez Posted December 10, 2010 Posted December 10, 2010 A bolt is a bolt and a nut is a nut(doesnt mean you have a pair of metal nuts in your scrotum mind) Quote
jezza Posted December 10, 2010 Posted December 10, 2010 i think the manifold to cyl head nuts are m10 fine thread. I would def use genuine nuts for the mani. They require a 14mm spanner which helps as some aftermarket manis don't leave much space around the head studs. Does your mani have studs for the turbo? If not i could prob send you bolts for that and nuts for the decat which is normally just mate studs. I would advise against using stainless fasteners due to dissimilar metal corrosion. Quote
Steve GT Posted December 10, 2010 Author Posted December 10, 2010 the mani to turbo does have threaded bars on them just need some nuts to go with it jezza Quote
jezza Posted December 10, 2010 Posted December 10, 2010 otherwise known as studs would need to know thead size in that case. Most likely fine thread for which i can't help you. Quote
Idrees Posted December 10, 2010 Posted December 10, 2010 As the others said, I'd recommend buying them from Toyota. Quote
Steve GT Posted December 10, 2010 Author Posted December 10, 2010 jezza il investigateiddy- yeah thats what im thinking any one got part numbers for all the bolts i need? Quote
Stulet-GTT Posted December 11, 2010 Posted December 11, 2010 i got mine from toyota, cheap as chips they were...Actually i think i still have the mani bolts as didnt use them in the end... Quote
