the quiet achiever Posted January 2, 2011 Posted January 2, 2011 hi got my civic rad & jezza`s mounts fitted but find the civic outlets are larger than ep size what do i need to fix i had a new set of silicone to fit as well is it easy or expensive ?? thanks for help lyle Quote
_shaun_ Posted January 2, 2011 Posted January 2, 2011 from what ive herd its a tiny diff and with lil bit of a stretch /boiling water should fit on Quote
the quiet achiever Posted January 2, 2011 Author Posted January 2, 2011 hi guys just to check we are all talking about the same thing i have measured the outlets ep = 28MM civic = 32mm i`m using the samco kit will the silcone soften when hot or stretch more i just been trying with some lanolin spray lyle Quote
Stulet-GTT Posted January 2, 2011 Posted January 2, 2011 Like said WD-40 or silicone spray for the top hose...When i fitted mine i found it easyer to fit the top hose befor putting rad in... Quote
Nanglebadger Posted January 2, 2011 Posted January 2, 2011 and fit them to the radiator OFF the car! Jay did this with mine and he found it MUCH easier than trying to do it on the car.Phil. Quote
Maz90 Posted January 2, 2011 Posted January 2, 2011 I have just spent about an hour there getting mine on.There a pain in the arse,but eventually go on.Good luck lol. Quote
micky boy Posted January 2, 2011 Posted January 2, 2011 KY jelly can also help slip it on haha .. Quote
Lee_EP82 Posted January 2, 2011 Posted January 2, 2011 Put them in some boiling water they will go nice and supple and slip on Quote
