Dezasster Posted January 5, 2011 Posted January 5, 2011 Hi AllI would like to introduce myself to the club. I have bought a 96 glanza 4 months ago. Already Came with some great mods. But i'm currently doing some upgrade and more tuning.Current mods include a red SSCUS bucket seat, Sard fuel pressure regulator,Walbro fuel pump,75mm Ross forged piston,ACL bearings and Thrust Washers, Civic double core radiator, TD04L turbo, Bigger Injectors, Bigger Front Brake Calipers, Blitz BOV, Blitz Boost Controller, HKS actuator,15" Rims, Momo steering wheel,Phantom Autometer 3 pillar gauge for boost/vaccum,oil pressure,air/fuel mixture. My current high boost setting is on 0.7bar.Current Tuning UpgradeFront Mount IntercoolerOil Catch CanGlanza Carbon Fibre eyebrowsWhat I'm Looking for to buyA new Triple Core radiator,reservoir socks, pauter forged rods, Athena Gasket, ARP Headbolt, roose motorsport ancillary hose, cooling panel,bigger exhaust(j performance), Heat wrap for manifold and finally an ECU as I'm still on stock ECU. Quote
Dezasster Posted January 5, 2011 Author Posted January 5, 2011 This is my carbon eyebrows that i'm gonna put on my Glanza.Currently Building my list for my Glanza. I will upload pictures as soon as possible. Quote
ryan lang Posted January 5, 2011 Posted January 5, 2011 guessing thats a photoshop in your avatar?if not that looks pretty mental hahaplans sound good, get some pictures up mate Quote
Dezasster Posted January 5, 2011 Author Posted January 5, 2011 guessing thats a photoshop in your avatar?if not that looks pretty mental hahaplans sound good, get some pictures up mateYeah it is indead, not posted my car yet. It's still in the garage doing some upgrade. As you can see the rear bumper is a Chargespeed bumper for the Subaru impreza. I found it to be really fierce on the glanza. I want to get one and then make a fitting and also keep the oem glanza front bumper with carbon fibre eyelids. I was looking for people who can actually make one to fit glanza. A company offered to make 75 to 80 percent alike.I will update pictures Quote
N80Jamie Posted January 15, 2011 Posted January 15, 2011 Get the pictures up mate! Want to see this beast Quote
Dezasster Posted January 19, 2011 Author Posted January 19, 2011 Hi all, I have just ordered a set of ARP headbolts and custom 1.6mm metal gasket from Speed vision. Also a new double core TD04L radiator and racing slim fan. I should get it by next week and hopefully solve my overheating issue. Current IssueCar went in the garage because of coolant loss and overheating. We took off the head and replaced valve stem seals and new oem Toyota gasket. Did a fist day run and was fine. On the second day temperature stayed in high after some high boost. We replaced to a new radiator and then after a while of road test the car did the same thing again. He removed the spark plug to found water with the spark plugs, as the car was making some weird noise at idle. The cylinder head was already skimmed when we did that oem 1.2mm gasket change. My mechanic who has a glanza as well advised me to use Metal MLS Gasket and ARP headbolts. I think the mistake as been the use of OEM headbolts which might have been stretched and was causing problem on high boost with that TD04. I have also change to a new water pump as the old one as one blade broken off. ;) Quote
Dezasster Posted January 19, 2011 Author Posted January 19, 2011 As the car is in the garage ive not have time to take pictures. I have found one with similar colour and look to mine. The only 2 main dif is that mine as a beautiful pair of red SCUSS bucket seat and alloy wheels.I have also posted a link of how we in seychelles dyno our Horse power. lol Please watch till the end:)Here is the another 2 videos of the car, It is now tuned to be the fastest car on the Road of Seychelles. Look at crowd. Hope you enjoy Quote
Sparky Posted January 19, 2011 Posted January 19, 2011 What boost was you running mate?Was planning on running 1.4 bar on the standard headbolts so maybe I will need some ARP's then. Quote
Dezasster Posted January 20, 2011 Author Posted January 20, 2011 What boost was you running mate?Was planning on running 1.4 bar on the standard headbolts so maybe I will need some ARP's then.we went up to 1 bar with an FCD. But my headbolt may have been reused a few times and never changed. They are TTY and tend to stretch after using them over again. ARP's will be the way with those alluminium cylinder heads.Your case might be different if they are new or used once but i advice ARP to be safe than sorry. Just Bulletproof the head. But i think the TD04 gives a bit more compression at 1 bar compared to ct9 at 1 bar. Me skimming and using the standard 1.2mm might have worsened the issue(more compression and tension on the used headbolts). Usually we tend to increase the gasket thickness with bigger turbos especially you tend to high boost quite often. Mine is a daily driven car. Quote
_shaun_ Posted January 20, 2011 Posted January 20, 2011 bah need some proper management am running mine at 1.2 bar on td04 mines totaly stock engine with blitz access ecu ( although i have a emu read to get maped) need to get some pictures up so we can see this thing Quote
Dezasster Posted January 20, 2011 Author Posted January 20, 2011 bah need some proper management am running mine at 1.2 bar on td04 mines totaly stock engine with blitz access ecu ( although i have a emu read to get maped) need to get some pictures up so we can see this thing I'm missing the car already myself. How long you've been running TD04 on that stock. Because before i bought it the car has been running that TD04 for 4 years and it's probably issues i need to eliminate 1 by 1. But i'm aiming up to 1.5 with a fully tuned EMS standalone ECU. We have a good tuner for this ECU here. Quote
Sparky Posted January 20, 2011 Posted January 20, 2011 Yea I have just bought some ARP's to be safe Looking forward to seeing some pics of this mate Quote
Dezasster Posted February 2, 2011 Author Posted February 2, 2011 Hi guysHere are the pictures of my old Cylinder head. Its been badly eaten by corrosion in several location. WATER leaking into the cylinder head. Anyway i have a new cylinder head ready to go on. Also picture of my car as it stand. Mechanic is currently fitting FMIC and ARP Bolts and MLS gasket,Racing Slim Fan and New Double Core TD04L radiator.New CHInside CarOutside CarI'll keep the update, Car will be getting new lip and lights and New paint job Quote
Dezasster Posted February 15, 2011 Author Posted February 15, 2011 Thanks to Dave Burwash at TM development for the Athena and some RED reflective TOM's and JAM racing stickers Quote
Dezasster Posted February 16, 2011 Author Posted February 16, 2011 here are the pictures with bumper off. Rocker cover painted Quote
Dezasster Posted March 7, 2011 Author Posted March 7, 2011 Intercooler Fiitted, waiting for Piping to be tig welded Quote
