REVISED DIY brake upgrade
  • Replies 84
  • 2 years later...
  • 4 weeks later...
  On 8/24/2016 at 12:12 AM, richardc9052 said:
Just use ae111 twinpots with Mr2 vvti front disks. bolt on, not spacers,shims or drilling... Just a little grinding to the carrier
there 5mm skinnier then the opel disks richard sure that cant be a good fit as the twin pot callipers require 25mm thick disks
the rest of the size is perfect by the looks of it
  On 8/24/2016 at 9:55 AM, russ78 said:
Mr2 discs are not centred to the carrier which will cause uneven pad wear imo not a suitable disc at all.
if you require suitable discs I can supply them with all work done at a good price :)
so they require 2.5mm spacers behind the disc ??? to center it to the caliper
both discs have a hight of 43mm
Edited by 5e colin
here lads i found this disk 25mm thick and 256mm you guys think it will work the only concern i have is the hight of 41 ???
Listed Part number:
DSK809
Part Manufacturer:
Apec
Fitting Position:
Front Axle
Disc Type:
Vented
Disc Diameter (mm):
256
Centre Diameter (mm):
60
Minimum Thickness (mm):
21
Overall Height (mm):
41
Number of Studs:
4
  On 8/26/2016 at 7:27 PM, 5e colin said:
could you take a pic how well its centered to the caliper richard ??
the way i see it the outside of the disk is 5mm further away??? or am i totally of in my head ??
If it doesnt rain tomorrow ill take a wheel off and take a pic as they sit.
  On 8/26/2016 at 10:28 PM, morgey said:
Levin twinpots
Celica st202 carriers
astra 1.7tdci 277mm discs
Spigot ring to center/locate disc.
Longer brake lines
Celica pads.
Instant 277mm disc upgrade no machining needed.
2 years now i have been looking for the carriers
and the 1s that did pop up had a starlet tax on them costing as much as the twinpot setup
anyone reading this im still looking so if you have some affordable 1s :) pm me
thanks richard :thumbsup::thumbsup::thumbsup:
would be great if there spot on as it saves me 100e to get the astra disks cut down again
Why are people making this so difficult ?
Corolla e10 carriers , 00 onwards mr2 front disks and ae111 twin pots. As Richard was saying . Carrier needs to be modded a very small bit . No spacers or anything like that. It's almost a direct bolt on job.
I have done this on 3 cars over the past 2 years. Zero issues and great stopping power for little money
my cariers are from the twinpots foggy is that same alignment to the disk as the e10 carie ???
No twin pot carrier and e10 carrier has a different position . That's why it's used. If you use twin pot carrier you have to use spacers and odd ball disks
I went down my local scrappy were the first pair i came across.
1997 2.0l (3sge) gt
One just like this
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=152210500949&category=9886&pm=1&ds=0&t=1472316507193
1997 2.0l (3sge) gt
One just like this
sadly over here your not allowed on the scrap yards anymore to check yourself they say its an insurance thingy
no problem richard
are these e10 cariers hard gotten ??? or are they al the same on a e10 rolla 4efe/4afe/4age
