My single din flip up headunit, when fitted correctly, folds out and hits the a/c controls above it. I managed to change the angle to which it folds out but in order to see the screen and actually touch it I need it to be straight. Any idea how I can have the HU sit out another inch-2" so that it can fold up perfectly?
i had same prob im my glanza spent like 4-5 hours messing around with diffrent ideas and nothing would work and pratical :\ some 1 might have worked out a way to get it to sit in nicely but i couldnt see a way
Not sure if it would work but possibly get another stereo holder thing (cant think what to call it) and modify it to hold the head unit half way up and make a custom surround.
This :lol:
mine was a 7" screen and still didnt work also tryed were the ashtray was n still couldnt get it flat enought for the touch screen to work
I've got a single din 1 with a 7 inch screen too, i fitted mines in the bottom bit as dan said and it fits perfect if i tilt the screen a bit.
if you do fit it like that make sure you take your bottle of juice out your cup holders before closing the screen or your screen will hit it!
Cheers for the feedback guys.
I had a play around today and I managed to get the brackets to fit in an odd way and still hold the other black space below it without being screwed together (somehow) and had that fit quite well. Had to adjust the tilt a tiny bit but i'm making progress.
Did have to shave parts off the cover that goes around the a/c controls and hazard buttons etc, but nothing major.
the screen has to flip out fully before it will work mate. plug it in and switch it on before you fit it and you should be able to tilt the screen forward a bit then when you refit it, it wont hit the heater controls
