Craig_T Posted January 21, 2011 Share Posted January 21, 2011 Alright,Just wondering where is the best/cheapest place for Rota Grids?Want some 15x6.5 in white. Quote Link to post Share on other sites
ToyotaTech15 Posted January 21, 2011 Share Posted January 21, 2011 Try rare rims,I got mines from there a few years ago, quite cheapGary Quote Link to post Share on other sites
Dan507 Posted January 21, 2011 Share Posted January 21, 2011 there pretty cheap in Driftworks, i'd recomend getting the Grid V's tho ;) Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 Yeh I looked on there Gary, they went up in price, probably due to the VAT..Is the V's the one with the dish?Not sure how they'd be on big brake clearance, as that is the only reason I am getting new wheels too. Quote Link to post Share on other sites
fulham4eva Posted January 21, 2011 Share Posted January 21, 2011 rimstyle are pretty good Quote Link to post Share on other sites
Sparky Posted January 21, 2011 Share Posted January 21, 2011 Dished or not the clearance all depends on the offset Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 Yeh but say the wheel is like this..\=/The equals being my calipar, and the slashes hub outwards, wouldn't the dished ones have less clearance as they have to go closer in at one point to get the dish on the spokes? Quote Link to post Share on other sites
Dan507 Posted January 21, 2011 Share Posted January 21, 2011 On driftworks the v's are 15x7 ET20 Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 I don't actually understand offsets, so means nothing to me LOL Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 Higher offset, more clearance I will have? Is that right.. Quote Link to post Share on other sites
Sparky Posted January 21, 2011 Share Posted January 21, 2011 Lower the number the further the wheel will stick out Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 Right.. So then if I have a low offset, will it not end up sticking out too much? What offset is usually used on starlets? Quote Link to post Share on other sites
Amjad Posted January 21, 2011 Share Posted January 21, 2011 Lower offset, more clearanceET38-40 for Starlets Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 So does anyone know if 15x6.5 ET40 Rota Grids clear Ksport/wilwoods? Quote Link to post Share on other sites
Glanza_cl Posted January 21, 2011 Share Posted January 21, 2011 doubt it... most upgrade to 16's with big brake upgrades.I would look at 16x7/8 et 38/40. but if you realy dont want 16's then possible 15x7/8 et 30/35 Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 I know Ksport and wilwoods fit under 15's, I not going 16's. It is the calipar hitting on spokes, not the size of the disk so it is just a case of the offset. Quote Link to post Share on other sites
Glanza_cl Posted January 21, 2011 Share Posted January 21, 2011 can allways get the most common type as finding a low offset isnt allways easy so there will be loads of 15x7 ET35 grids... then you can just get some spacers if needed to clear the calipers. 5-10mm spacers should clear it no probs ;) Quote Link to post Share on other sites
Keri-WMS Posted January 21, 2011 Share Posted January 21, 2011 Alloys with any "dish" or lip are a nightmare for fitting brakes, makes more difference than offset in many cases!Or buy a kit that fits in the first place, the WMS 277x25 kit should fit under most 15's, and failing that there's another 3mm of spoke clearance available with the 275x22 size.... ;) The trouble with changing the wheel offset from factory standard is it messes up the handling, tends to induce torque-steer and squirming under braking. Quote Link to post Share on other sites
Sparky Posted January 21, 2011 Share Posted January 21, 2011 My Wilwoods clear my Final Speeds ;) just about, not a massive offset either probably between et38-40 Quote Link to post Share on other sites
lew777 Posted January 21, 2011 Share Posted January 21, 2011 Mine are 15s with wilwoods and 10mm spacers Quote Link to post Share on other sites
Liam_D Posted January 21, 2011 Share Posted January 21, 2011 As said mate, rarerims or Driftworks are the best for Rota wheels mate. Quote Link to post Share on other sites
Craig_T Posted January 21, 2011 Author Share Posted January 21, 2011 Cheers liam but we are onto sizes and stuff now ;)Hmm, someone must have some grids with big brakes? Quote Link to post Share on other sites
Glanza_cl Posted January 21, 2011 Share Posted January 21, 2011 as above mate, they will fit but you probably will need some slip on spacers... 10mm couple of quid, job done, sorted ;) Quote Link to post Share on other sites
Craig_T Posted January 22, 2011 Author Share Posted January 22, 2011 Want to go without spacers though thats the point. If rota's don't fit, then I will just put spacers on my wheels I got on now... Quote Link to post Share on other sites
