Mattb504 Posted January 29, 2011 Share Posted January 29, 2011 Theres a loudish knocking coming from passenger side front wheel.. Happens when pulling away and putting foot down.. Had a look and changed c.v joint. Still no joy, been round checked evething and all looks tight. Any suggestions??? Quote Link to post Share on other sites
GT Phayer Posted January 29, 2011 Share Posted January 29, 2011 lower arm bush or engine mount ? Quote Link to post Share on other sites
Mattb504 Posted January 29, 2011 Author Share Posted January 29, 2011 GT Phayer said: <br />lower arm bush or engine mount ?<br /><br /><br /><br />Cheers will have a look tomorrow Quote Link to post Share on other sites
Stulet-GTT Posted January 29, 2011 Share Posted January 29, 2011 GT Phayer said: lower arm bush or engine mount ?I would think this to, had it on my 106GTi every time i put foot down would hear knock an it was lower engine mount lose.... Quote Link to post Share on other sites
Mattb504 Posted January 30, 2011 Author Share Posted January 30, 2011 Have checked engine mount n lower arm bush they looked fine.. Any other ideas Quote Link to post Share on other sites
ryan lang Posted January 30, 2011 Share Posted January 30, 2011 what car is it bud? n/a, glanza or gt Quote Link to post Share on other sites
Mike_trx Posted January 30, 2011 Share Posted January 30, 2011 Sounds daft but check the door hinges mate, had a similar noise and thought it was CV joint until my mate tried opening the doors and lifting them...felt a bit stupid after it. Replaced the hinge on the offending door and that was that. Quote Link to post Share on other sites
madmax_926 Posted January 30, 2011 Share Posted January 30, 2011 Mattb504 said: Theres a loudish knocking coming from passenger side front wheel.. Happens when pulling away and putting foot down.. Had a look and changed c.v joint. Still no joy, been round checked evething and all looks tight. Any suggestions???it was one of the gearbox mounts on my car and passenger could actualli feel knocking under their feet Quote Link to post Share on other sites
ryan lang Posted January 30, 2011 Share Posted January 30, 2011 if its an n/a with a glanza/gt strut brace it could be that knocking, mine does it Quote Link to post Share on other sites
daz gt turbz Posted January 31, 2011 Share Posted January 31, 2011 again another stab in the dark from personal expierence but jack the car up and shake your exhaust. i had a knocking noise under acceleration and hard cornering and it turned out to be my exhaust. like a said a stab in the dark but maybe worth a check! Quote Link to post Share on other sites
gaz Posted January 31, 2011 Share Posted January 31, 2011 Look brake caliper? Quote Link to post Share on other sites
StarletMad Posted January 31, 2011 Share Posted January 31, 2011 I have this noise too mate... Yeah i guess it only really happens when perhaps the wheels just starts to spin a little when hitting full boost or when you pull away sharply from a junction. Quote Link to post Share on other sites
biscuit Posted February 11, 2011 Share Posted February 11, 2011 I have this also - Quote Link to post Share on other sites
madmax_926 Posted February 11, 2011 Share Posted February 11, 2011 I PROMISE YOU ITS THE REAR GEARBOX MOUNT POLY BUSH IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Quote Link to post Share on other sites
biscuit Posted February 11, 2011 Share Posted February 11, 2011 Are you sure it's not going to be CV joint?I only get it when I am on 1/2-full lock and using the throttle, just idle/rolling in gear there is no sound.Will check it tomorrow - let me know! Quote Link to post Share on other sites
madmax_926 Posted February 11, 2011 Share Posted February 11, 2011 biscuit said: Are you sure it's not going to be CV joint?I only get it when I am on 1/2-full lock and using the throttle, just idle/rolling in gear there is no sound.Will check it tomorrow - let me know!it says he changed this (top post) Quote Link to post Share on other sites
