  • Replies 133
  • Created
  • Last Reply
Top Posters In This Topic
awsome build, good skills
cheers :D
right not much done to the car today as i been busy repairing some seats which i hate doing !!!!
i did get around to removing the last of the sound deading in the boot tho,
then i removed the spare wheel holder as i was bored and its going to be in the way of my new fuel system, which i hope to be able to cover over in the spare wheel well
also i need to find out what pipes go were on the fuel tank if any one can help?
whoop i love when bits come and i had some come today!
now i finished off the wiring in the fuse box and it all connected up to the cut off switch on the dash
and i was lucky that i could hide the wire below the fuse box as well
all crimped on ready to be bolted in
bolted in with a new 100amp fuse
also i my brake lines have come also so i got them fitted! but being a twat i have order the wrong color as all my brake lines are blue and these are clear so you can see the braid but dam they look good,
also i finished the rear lines too by bolting them to were the abs wire was
right had another spare 5 mins on the car tonight, which i done a wire tuck on the fuel pump and removed more abs wiring heres how its looking like now, with just my brake lines showing,
whoop! its getting there now!
right had a packet come yesterday with my new ht leads for V, form cj performance,
and there in a lovely blue to match the other bits !
also i started to work on the block as it back all rebore to fit the new pistons, i have started to polish the inside of the bottom end, not touching the bores or were the bearings sit. on the 4/5e blocks there a easy mark to follow so you are no were near any of the bearings,
i hope this will help keep the engine cleaner and not trap any rubbish in the roughness of the casting,
oo make sure you get a pic of the block when its all polished . will look insane ;) never noticed your reply about the brakelines mate. i wouldnt mind the sizes of them dude as they look the part :rolleyes: send me a pm or something if ya wish :p
Must be some updates from the weekend Mark?
mike long time no speak! how you getting on? and only update this weekend is that i picked the bearings for the bottom end,
awesome work going on here bud nice 1
awesome work mate, wish i could work like that
pat yourself on the back lol
cheers lads,
i really just started to clean the inside up i wanted to do the crank as well but i need to find out how much to reblance the crank would cost,
and i might be selling my front brake lines as they are the wrong coulor, i sort out the sizes for you,
tiny update! i have ordered the last bit (for now) to finish my brake lines, but i had to make up a bracket to hold the new valve so the work shop stores was my first stop!
i found 2 big square washers which worked a treat as i cut one down to support the other
and then this is it in in front of the handbrake, ready to be welded in
right as you lot know i ordered the last bit of my brake lines the other day and it turned up now so i can finish the brakes until i can afford to fit twin master cylinders and a blance bar,
i ended up taping the holes on the valve so i could bolt it to the fixing plate, also i need to clean up the welds as they are shocking :) and get it in some primer ready to spray inside at a later date,
also i had a tiny bit of flock left, so i started to flock one of the new panels were the cut off switch is but sadly run out of flock :p
as the weather isnt great here i got on with the last bits of cleaning inside the engine, so with that done i started to crank on and build up the bottom end,
first was to clean the crank and block ready for the main bearings,
next was to make sure the bearings were covered in oil, thrust bearings were placed in, then to place the crank on the bearings
the main caps were fitted ready to torgue up now,
just a pic of the bearings that have been fitted
  • 3 weeks later...
havent done a update for a bit,
right i have got the engine nearly built now just waiting mainly on the con rods for it now,
the rocker cover is having two -8an fitting welded to it and also been sanded down so its nice a smooth now ready for powered coating,
also i just got a AEM wideband which is now fitted ready for the down pipe to have a bung welded,
Amazing work on this project, hats off! So much better when all the work is DIY.
idrees i wish i had the skills of some of the people on here, but the only way i learn is by getting my hands dirty and having a go at it
and thank you for the comments,
right i been working on my rocker cover lately as i been saving for the next big bit,
it started life looking like this
so i striped it and started sanding it down but sadly got a bit carried away and sanded all the ridges of it!
then i sent it over the road to be all the fitting welded on
then to finish off a couple coats of primer ready for the finial colour
