am after turbo my starlet sr in the future, but for now just asking making it a little bit fast cud any tell me what wud the best way plus found this on ebay http
://cgi.ebay.co.uk/Toyota-Starlet-Glanz...item2a0ece8be7
wud this help it, had it decated couple of week a goo and i can feel he differents plus tuk everything out the back. thanks alot
Yeah, the worse part is taking the old manifold of.. 1 hour max if you know what your doing and have the right tools :thumbsup:
where about did u get your from that a good price ???
Luke and his dad helped me fit mine. :ph34r: the thing is the rolla manis hardly ever come up for sale so its just if you want one or not. got mine for £25 from scrappy but thats CHEAP.! should look to spend from around £30 to £50 for one. Depends how much you want one really. :thumbsup:
some guy told me this is he rite ??? 4efe can make 128bhp, stick with it for a while tuning, everyones says just turbo it just turbo it, but just spend your money on things you could use on a turbo engine too like a piggyback ecu etc. Keep it well serviced with new oil filter and 10w-40 oil dont put 20w-50 race oil its too thick and heavy. Let her warm up before racing and dont sit on the rev limit, 5500rpm is where the power stops.
Corolla inlet manifold, decat, any backbox you like 2inch maximum hole and get a piggyback ecu. Dont spend £200 on a exhaust manifold you dont need, and dont bother with trd thin headgasket until you need to do piston rings and valve stem oil seals at which point you will fit fte turbo valve springs or turbo cylinder head if you can find one for £50 or less. Check your fuel pressure by having you mechanic fit a double banjo bolt on top of fuel filter. I used a fte turbo fuel pressure regulator because my 4efe was very old and turbo one was only 40k miles old.
With a throttle body included yes, I paid £50 for mine without.
Depends though, most go for £50 on here or you can pick one up at a scrappy if you are lucky.
Youll defo struggle to get 128bhp out of a fe mate.! :thumbsup: Do mods such as air filter with cold air feed. back box. rolla mani. decat. will get you to like 90ish bhp i think.
mite as we droa turbo in it
What?
Your asking us how can you make your n/a a bit quicker, we tell you then you say that.. :thumbsup:
No point spending mega money on these little engines without a turbo, well thats my view anyway :ph34r:
Corolla Manis mate a awesome difference. Defiantly a mod thats worth doing :)
Or you can do what liam did. :thumbsup: Left us n/a's for BOOST :ph34r: What a car his is though B)
On a serious one mate rolla mani and a decent cold air feed induction kit makes a massive difference.
off topic slightly lads.. but will a 4EFTE inlet and throttle body do the same job? :/
Should do, it has a larger inlet as well so moar air :thumbsup:
