Keri-WMS Posted March 18, 2011 Posted March 18, 2011 Effects n/a:2.0 > 2.2 is a 10% increase in capacity/output. That's the same as adding 1.45psi of boost to a n/a 2.0 (ie, an extra 10% of atmospheric at sea level).Effects f/i:Take an ST205 spec 2.0 3SGTE as a base, running stock 10.8psi and go 2.2.....(10.8+14.5 = 25.3psi total) then (25.3psi x0.1 = 2.53psi extra). So that's 10% more power, or the same as adding 2.53psi, ie going from 10.8psi to 13.33psi.So the options that make sense (increasing in power) are:1 - fit a 2.0 n/a because it's cheap2 - fit a 3SGTE because it's "easy"3 - turn up the boost on the 3SGTE!!!!!!! An extra 2.53psi is the same as going 2.2L.4 - build a 2.2 3SGTE based thing, but be ready to have to have full aftermarket internals if the 2.2 stuff is weak.Building a low-boost 2.2 is pointless. If you want to piss about with low boost build a turbo BEAMS, THAT would be worth talking about! Quote
ryan lang Posted March 18, 2011 Posted March 18, 2011 is 40,000bhp even possibleor was it meant to be 4000? Quote
Keri-WMS Posted March 18, 2011 Posted March 18, 2011 is 40,000bhp even possibleMaybe with a bigger turbo.... Quote
Sparky Posted March 18, 2011 Posted March 18, 2011 Be needing more than a 2.2 to spool those bad boys Quote
siren676 Posted March 18, 2011 Posted March 18, 2011 May i ask what on earth would need a turbo that size? Quote
Keri-WMS Posted March 18, 2011 Posted March 18, 2011 May i ask what on earth would need a turbo that size?A big engine! Quote
siren676 Posted March 18, 2011 Posted March 18, 2011 Alright who wants to put that into a starlet? I think it may affect the handling a tad Quote
