minispark Posted April 9, 2011 Posted April 9, 2011 hey guys can anyone tell me are ep91 wishbones the same/fit the same as ep82? i.e can i put 91's on my 82??? Quote
bumblebee Posted April 9, 2011 Posted April 9, 2011 hey guys can anyone tell me are ep91 wishbones the same/fit the same as ep82? i.e can i put 91's on my 82???depends on what model EP82...since the MK1's lower control arm bushings have a different diameter..later model GT's are the same as the EP91's if am correct...89-92 starlets- have a bushing diameter of 31mm O.D while the later models are 34 mm O.D it may be the other way around but...you get the idea Quote
llawgoch Posted April 10, 2011 Posted April 10, 2011 98 onwards ep 91 had a different rear bush and is not interchangeable, theres a big black metal bracket holding it on, it should be obvious when you look at it Quote
minispark Posted April 10, 2011 Author Posted April 10, 2011 98 onwards ep 91 had a different rear bush and is not interchangeable, theres a big black metal bracket holding it on, it should be obvious when you look at itmine is a 91 model! H plate! so can i not use any wishbone off of an 82? or if the wishbones from the 91 come with all the bushes will it still not fit?? Quote
minispark Posted April 10, 2011 Author Posted April 10, 2011 mine is a 91 model! H plate! so can i not use any wishbone off of an 82? or if the wishbones from the 91 come with all the bushes will it still not fit??help!!!! Quote
G14 NZA Posted April 11, 2011 Posted April 11, 2011 All GT's and early Glanza's use the same "D" bracket and the same long bolt at the front so they should be interchangable no matter what diameter the front bushes are.Mark Quote
JamesD89 Posted March 24, 2017 Posted March 24, 2017 (edited) All GT's and early Glanza's use the same "D" bracket and the same long bolt at the front so they should be interchangable no matter what diameter the front bushes areMarkSorry to dig old thread up but can anyone confirm that this is correct?Cheers Edited March 24, 2017 by JamesD89 Quote
