drilling of carbon fibre bonnet for washer jets,
My stock n/a bonnet looks like its gonna rip off at high speeds :p:(:(:p
Enzo mentioned single wipers... i was just wondering if they are available for the ep91 I've seen em for ep82s but not the 91s :p
Or does anyone know if the 82 ones would fit the 91?? :p
single wipers are mega chav. dont do it!
and drilling carbon...
tape it up on the top side, and drill an uber small hole as pilot, then get a tapered drill to open the hole up SLOWLY.
then stick some glue in it to seal. let it dry and off you go.
I think the thing Geo is looking at is a bit that clips onto single wiper arms... not a conversion (as far as I'm aware.)
yea mate thats the craic :p
done this last weekend, piece of piss enzo.
masking tape the bonnet up roughly where your jets go.
mark up in pen the shape you need, measure it and make sure there not pissed.
drill the center hole with a tapered drill bit, (the type that has a tiny point , leading to the stanard drill part)
then use a small square detail file to file for the pins either side of the hole.
dont go over kill or you will have a gaping hole around the edge of the jet.
mine fit extra tight, which is good because they dont leak through.
on the underside once mounted, use a bit of mastik to seal around the edges. et voila done.
just drill using a hand drill , and file extra slow and gentle with out much pressure and it wont chip the carbon.
