Glanza AuA Posted May 9, 2011 Posted May 9, 2011 sub guys did a compresion test today and these are the resultsdry test: 165 170 165 170wet test: 175 175 175 175basicly the reason i did a compr test is becasue from time to time the car sometimes idles whitesmoke like crazy,a white smoke that basicly clears my whole yard lol,as soon as i give it a rev everything goes back to normal again,it only happens sometimes also theres this crazy burning oil smell comming from the white smokerecently got the car from japan and has 126.000 km driven on itcould you guys give me some advice to what is happenig to my glanza?could it be turbo seal or stem seals?? already changed the pcv valvethank you in advanced Quote
turbo Grant Posted May 9, 2011 Posted May 9, 2011 Recon it will be the valve stem seals. Comp test looks good. When tgeturbos gone they tend to smoke all the time. You can change the valve stem seal with out taking the head off. Just need a bit of compressed air and a special universal tool to compress the valve springs :-) Quote
Glanza AuA Posted May 9, 2011 Author Posted May 9, 2011 Recon it will be the valve stem seals. Comp test looks good. When tgeturbos gone they tend to smoke all the time. You can change the valve stem seal with out taking the head off. Just need a bit of compressed air and a special universal tool to compress the valve springs :-)thx a lot for the reply mate i know about the compresion valve tool!! actually we sell them at my work,do you think its a easy do it your self job ??will have a look at it tommorow thx mate Quote
Guest tubby_ep82 Posted May 10, 2011 Posted May 10, 2011 As above the compresion test looks good, So no need to worrie about that, It sounds like your vale seals are on the way out, Or maybe time for a new turbo, But to me sounds like the vale sealsRegards Quote
lukEp Posted May 10, 2011 Posted May 10, 2011 Give the pcv valve a clean with petrol first to see if it solves your problem Quote
Socks Posted May 10, 2011 Posted May 10, 2011 stuffed up breathers would give blue oil luke not white Quote
Guest tubby_ep82 Posted May 10, 2011 Posted May 10, 2011 White smoke would be Turbo unit or the vale seals, Correct me if im rong Regards Quote
turbo Grant Posted May 10, 2011 Posted May 10, 2011 Easy job to do as long as your happy timing your engine up. You need to remove the cams. When you slide the new seals on make sure you oil them up, and put a bit of thick plastic bag over the valve so you don't catch the new seal going on. Quote
nastyrash 2003 Posted May 10, 2011 Posted May 10, 2011 yep white smoke is either fuel or water, and japan has just bin under a lot of water wen u bye this. does it miss fire check if water is getting down past your plugs. Quote
Glanza AuA Posted May 10, 2011 Author Posted May 10, 2011 yep white smoke is either fuel or water, and japan has just bin under a lot of water wen u bye this. does it miss fire check if water is getting down past your plugs.haha no way ,my glanza shiped on march 5th tsunami on japan happen on the 9th or 10th of march dont really remember,recieved the car on april 1st also,the white smoke thats comming out is a smell of burning oil,also i did noticed a drop in oil level tough, and no the car does not miss fire in anyway runs super smooth Quote
Glanza AuA Posted May 10, 2011 Author Posted May 10, 2011 Easy job to do as long as your happy timing your engine up. You need to remove the cams. When you slide the new seals on make sure you oil them up, and put a bit of thick plastic bag over the valve so you don't catch the new seal going on. no way im taking the cams of bro to afraid of messing things upgeuss ill take it to a mechanic than,i really appreciate the info man thx a lot cheers Quote
Glanza AuA Posted May 10, 2011 Author Posted May 10, 2011 thx a lot for all the help guys,will try some of your advices, you guys are the best sry for the bad english typing not my original language,your helping a dude all the way from a island called Aruba, will report back if i manged to solve itcheers Quote
Glanza AuA Posted May 10, 2011 Author Posted May 10, 2011 As above the compresion test looks good, So no need to worrie about that, It sounds like your vale seals are on the way out, Or maybe time for a new turbo, But to me sounds like the vale sealsRegardsthx mate will change the valve stems first and than go after the turbo Quote
adz_sportif_turbo Posted May 10, 2011 Posted May 10, 2011 if it only does it on idle deffo stem seals Quote
