Amjad Posted May 24, 2011 Posted May 24, 2011 My braking setup on the GT (1bar CT9) will be:- Standard Calipers- RedStuff Pads- Braided brake lines- Toyota DOT 5.1 FluidJust wondering what front discs to order. A lot of people go for the ebay drilled/grooved ones, I'm not not too fussed about all that, but I just want some which will be decent for road/fast road use but also discs that won't fade/crack on track under hard useA few people have said just to get some new OEM discs rather than the drilled/grooved ones. What do you think guys?Amjad Quote
WallaceGlanza Posted May 24, 2011 Posted May 24, 2011 Any of those in the standard size will fade on the track. Quote
Amjad Posted May 24, 2011 Author Posted May 24, 2011 Well the ones which will fade the least then I will eventually be getting GT4 brakes but not for a while! Quote
cazzac2222 Posted May 24, 2011 Posted May 24, 2011 For track use i think any setup on standard calipers just wont be good enough and will fade, but for fast road deffo look into something like i have for sale mate, the EBC grooved & dimple Discs with the Yellow Stuff Pads, i loved mine but going Twinpots now as i plan for a few track days in the future Quote
Georgie Posted May 24, 2011 Posted May 24, 2011 i have grooved discs and they are very good, just don't get the drilled ones as they soon start to crack around the drilled holes then its time for new ones Quote
Amjad Posted May 24, 2011 Author Posted May 24, 2011 Thanks but I'll be buying new, seen the RedStuffs and new CRN drilled/grooved discs going for £120ish on ebaySurely standard sized discs can't be that bad? I've only ever had fade on my NA brakes and they're drilled/grooved with GreenStuffsYeah that's what I heard Georgie to go for just grooved over the drilled/grooved, just wondering because a few people recommend OEM discs too Quote
Giggz Posted May 24, 2011 Posted May 24, 2011 I run on grooved discs on the front with green stuff pads atm. Quote
Sparky Posted May 24, 2011 Posted May 24, 2011 Grooved I would go for.But saying that I managed to fade the Wilwoods, so glad I got rid of my old set up Quote
LukeSR Posted May 24, 2011 Posted May 24, 2011 You going for Redstuff pads Amjad? Ill just be running Redstuff with OEM disc's for the 15 min run @ Donnington Quote
Amjad Posted May 24, 2011 Author Posted May 24, 2011 I run on grooved discs on the front with green stuff pads atm.Grooved I would go for.But saying that I managed to fade the Wilwoods, so glad I got rid of my old set up Hmm might consider the grooved ones then...You going for Redstuff pads Amjad? Ill just be running Redstuff with OEM disc's for the 15 min run @ DonningtonYeah RedStuff have decent reviews and Keri @WMS recommends them too. I'm still unsure on the discs, think it was David Ashton and Enzo that recommend using OEM ones Quote
LukeSR Posted May 24, 2011 Posted May 24, 2011 I'm not gonna be going MAD on the brakes, engine braking FTW Quote
Amjad Posted May 24, 2011 Author Posted May 24, 2011 (Meaning I'm not planning to go easy on the car) Quote
Gadget Posted May 24, 2011 Posted May 24, 2011 I am also interested in this. I was looking at the ebay brake discs and pads and it looks all right.. but it's ebay is it worth the risk... Quote
Asad Posted May 25, 2011 Posted May 25, 2011 either go for a standard vented disc or a grooved one with say no more than 6 grooves i`d avoid drilled ones.....im putting in redstuff pads when funds allow so go for them? Quote
Idrees Posted May 25, 2011 Posted May 25, 2011 The answer you're looking for is 3G. Don't bother with the CRN discs, they are the stock ones (such as Blueprint OEM replacements) that have been grooved. I fitted a brand new paid to my old GT and I thought the old (battered) 3G discs performed better. Quote
Amjad Posted May 25, 2011 Author Posted May 25, 2011 Yeah Asad if I was to get grooved it would be the ones with fewer grooves Idrees I saw this when you first posted and was put off 3g..? lolBrake update - 3rd July 2009Fitted some new brakes, some serious cracks in the old ones!One brand new I wouldn't use again..[On with the new..CRN grooved discs with yellow stuff pads, £118 well spent on ebay, very fast delivery. Sometimes they do feel a little spongy, but they are still being bedded in so can't comment much further on them. Fitting wise they are excellent and easy to fit.Would you still rate the 3g's? I have seen a few reports on 3Gs cracking but never really heard anything bad about CRN discs. Quote
DavidAshton Posted May 25, 2011 Posted May 25, 2011 OEM for me if your sticking with the stock setup. The point in grooved discs is to allow gas/vapour between the pad and the disc to escape, can you really push the stock setup to those extreme's? I dont think so, way i see it less grooves, more surface area to brake with. I dont even think most proper performance brake setup's use grooves do Willwoods and such come with grooved disks? When I had grooved they made a horrible noise when braking, cracked from where the grooves started and i dont think they look any good when rust gets in all the grooves. I find the OEM replacements a much better balance between daily driving and spirited driving. I dont think the stock setup will ever be able to deal with hard driving, they fade very quickly, slam on from a ton and thats it, ive found this with both grooved and stock disks there just so small and thin. I do think though that the stock disks come back when pushed better than the grooved ones I had. The yellows and grooved I had always felt a bit glazed I never had good pedal feel with them, like they just didnt feel as if they were biting, stock set I think has a much better pedal feel. Ive even ditched performance pads and gone for ebc ultimax which are just stock replacements. Spot on from cold, no problems with sprited driving, die like the rest when hammered. Quote
