Lukew360 Posted June 11, 2011 Posted June 11, 2011 My glanza is on about 70k ish miles and uses virtually nothing! Quote
Misterdan88 Posted June 11, 2011 Posted June 11, 2011 V on 93k engine, as above nothing at all. checked this morning! Quote
Dan507 Posted June 11, 2011 Posted June 11, 2011 None, changed the oil in september, still on Max Quote
MARC MOSS Posted June 11, 2011 Posted June 11, 2011 Change mine every 3000 miles and I never top it up between , your using oil I gather ? Quote
Driver Posted June 11, 2011 Posted June 11, 2011 Mine had like 135k(in km) then a further 45k (in miles) and never used a drop, changing every 2500-3500 (oil and filter) never used anything in between Quote
DavidAshton Posted June 11, 2011 Posted June 11, 2011 After an oil change mine used to use half a litre in a week, top it up and it would be fine after that.It always ran fine though although it was a high miler on 193k km. Quote
mark-tozer Posted June 12, 2011 Author Posted June 12, 2011 Change mine every 3000 miles and I never top it up between , your using oil I gather ?yeh mines burning a bit of oil. no oil in intercooler pipes no oil in inlet manifold no play in turbo. not sure if its valve stem seals or piston rings is dosent seem to be pressurising the oil system. as no oil cuming out of dip stick of oil breather pipes. it doesnt always smoke only now and again. Quote
