mark-tozer Posted June 18, 2011 Posted June 18, 2011 ive got a toyosport exhaust manifold already i welded it a week ago as cracked now its blow again and i think its cracked the manifold in different place. so looking at getting a new or second hand one which is strong enough for 180bhp. cheers Quote
5T4R7ET N/A Posted June 18, 2011 Posted June 18, 2011 have a look in the for sale section. There mite be some ct9 manifold going.was you toyosports mani mild steel or stainless? Quote
mark-tozer Posted June 18, 2011 Author Posted June 18, 2011 are standard ones strong ported as ive got a standard one i can put on. the toyosport one ive got is stainless. Quote
tez Posted June 18, 2011 Posted June 18, 2011 for the money, a standard ported will do the same job as wepr, this is in my opinion and few members on tgtt.Cast iron is less likely to crack, than mild steel and espically stainless.hense why the standard one which is ported is the best option.theres people on tgtt done 40k+ on there standard ported manis at 1 bar so safe enough.dont get me wrong, a better option is wepr mild steel/equiv but for the money how better is it than the standard one? Quote
philpott Posted June 18, 2011 Posted June 18, 2011 how do people with porting skills that are non existent go about getting theres done because im in desperate need of porting or an uprated mani.. Quote
tez Posted June 18, 2011 Posted June 18, 2011 its not exactly skilled work. i did mine fairly easily, took a while mind.grinding stone & drilland grind away the area needed, take time and caution. Quote
mark-tozer Posted June 18, 2011 Author Posted June 18, 2011 Ok thanks for advice i will try a stanard one and port it myself ad ive got the standard one it wont cost me anything whats the most power someone has had out of a standard manifold before it cracks cheers Quote
Glanza_cl Posted June 18, 2011 Posted June 18, 2011 Ported standard mani will surfice for moderate boost levels i.e 0.8bar but imo even when ported limits the flow. Zisco or racetech would obviously be superior but if you are just going to stay on the standard ct9 and run standard boost levels (below fuel cut) a properly ported stock mani will do .Also its not about how much power before it cracks its about how limited the flow becomes through the small, short runners thats becomes an issue when hunting power figures. Quote
mark-tozer Posted June 18, 2011 Author Posted June 18, 2011 Im going to be running 1bar of boost i think i will try a ported stadatd one as havmt got alot of money at the mo Quote
N80Jamie Posted June 18, 2011 Posted June 18, 2011 I've got an awsome condition Zisco ram horn mani for sale! Quote
mark-tozer Posted June 19, 2011 Author Posted June 19, 2011 I've got an awsome condition Zisco ram horn mani for sale! how much do u want for that mate also does it keep the turbo in the same place. Quote
N80Jamie Posted June 19, 2011 Posted June 19, 2011 Was looking for £200 but I've snapped 2 screws while separating it from the turbo so £190 now and it will keep the turbo in the same place yes. Quote
