QUADLIGHT GT Posted July 4, 2011 Posted July 4, 2011 been meaning to post this up ages ago.. anyways >>as above guys^ my antifreze reserve bottle keeps on filling up (only whn on a long journey like motorway) basically after a good thrash its pumps antifreez out of radiator straight in resrve bottle ??has only been doin this over a year now , ive only been like on an hour motorway drives say bout 10 times in a year for shows etc only!anyone know why it is doin this ??Thanks! Quote
QUADLIGHT GT Posted July 4, 2011 Author Posted July 4, 2011 abviously it will over heat aswel when it pupms it into reserve bottle.. thn with the heaters on for 5 mins its fine.. & no air in rad pipes Quote
Socks Posted July 4, 2011 Posted July 4, 2011 its ether a gunge build up in the water system...try a flush with a new thermostat (like £7 new)if it still does it, headgasket.. or at least the start of it... Quote
QUADLIGHT GT Posted July 4, 2011 Author Posted July 4, 2011 is it worth doin a compression test.. ? only does it on a proper motorway blast other wise the its totally fine not had a single prob with the car. Quote
QUADLIGHT GT Posted July 4, 2011 Author Posted July 4, 2011 also what can cause this to happen ? Quote
craigant Posted July 5, 2011 Posted July 5, 2011 my old engine did this, turned out to be headgasket. try thermostat first though. Quote
QUADLIGHT GT Posted July 5, 2011 Author Posted July 5, 2011 my old engine did this, turned out to be headgasket. try thermostat first though.thermo was changed 4/5 months ago Quote
daz gt turbz Posted July 5, 2011 Posted July 5, 2011 mine does this every now and again, if it was headgasket wouldnt there be milky oily shit on the oil cap? Quote
templar2007 Posted July 5, 2011 Posted July 5, 2011 mine does this every now and again, if it was headgasket wouldnt there be milky oily shit on the oil cap?No mine was doin this and it was the Headgastet and I didn't have that milky shit.mine was water Comein out the bk Quote
ktl Posted July 5, 2011 Posted July 5, 2011 mine does this every now and again, if it was headgasket wouldnt there be milky oily shit on the oil cap?its not oil and water mixing its exhaust and water causing it to pressurise. thermo was changed 4/5 months ago Sniffer test it to find out 100%..... but you need to go for a blast around the block before doing it. Quote
lukEp Posted July 6, 2011 Posted July 6, 2011 Try a differerent radiator cap.X2 if it's excessive but that's what that bottle is there for, it will dump excess water into it when hot and as it cools it will suck it back in. Quote
shaungt Posted July 13, 2011 Posted July 13, 2011 i used to get this but i was running just under 1 bar on a standard hg the standard hg does not have all the watersways opened up so i got a better one and it sorted that proplem out Quote
