nazzurro19 Posted July 8, 2011 Posted July 8, 2011 right i finally went td04 yesterday night so today i went to the petrol station drove 1 mile home pulled up and theres coolant everywhere , its coming from the long rad pipe that goes to the pump , what has caused this ? it could be the pipe is loose or something but if its not what other issues could it be ?the overflow tank thingy has gone down a bit too and i took off the rad cap and the coolant was brimming then it went down again ? has it got too hot ?and lastly should the fan blow or suck ? cause atm it sucks and if you put ya hand behind the fan when its on you can feel lots of hot air is this correct? i dont wana drive the car and it blow up lol Quote
rorenapier Posted July 8, 2011 Posted July 8, 2011 From the metal pipe from the water pump?Sounds like its over heating and pressurising the system.Where is the fan located? outdide or inside?Indide should suck, outside should blow. Quote
iamlegend Posted July 8, 2011 Posted July 8, 2011 uprated rad cap?well go check to see if anything is loose lol!did you bleed the system threw? Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 the fan is inside the engine bay on the back of the radiator yeah when i fitted the rad i put coolant in the rad , let it run to temp then topped it up and filled the overflow bottle to full so by the sounds of it my fans on backwards ? Quote
Sparky Posted July 8, 2011 Posted July 8, 2011 Wait for the fan to kick in and see if it sucks or blows.If its blowing then all you need to do is swap the two wires round to reverse it.Oh and I have a 1.1bar rad cap on mine Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 i take it it blowing cause it feels like the heat is hitting my hand , so id say its blowing hot air into my hand from behind the rad so its probs wrong way round and over heated and pressurised and leaked a lil Quote
Sparky Posted July 8, 2011 Posted July 8, 2011 Put your hand behind the fan and if its blowing your hand then its sucking air through the rad which means its right Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 yeah it does the hot air goes towards the back of the car well ill try the hoses etc , i hope its something simples lol Quote
rorenapier Posted July 8, 2011 Posted July 8, 2011 Not so Sparky, yes you could change the polarity around, but think about the fan blade direction. If its blowing then all you need to do is swap the two wires round to reverse it. Quote
WallaceGlanza Posted July 8, 2011 Posted July 8, 2011 Not so Sparky, yes you could change the polarity around, but think about the fan blade direction. Was going to say the same myself, fans don't work as effectively both ways - I got a second hand rad with fan fitted on the engine side and assumed it should suck so that's the way I wired it up, however I've noticed the car getting hot when stood still even with the fan on. I checked last night and noticed the fan should be blowing - so someone bought the wrong fan (or put it on the worng side). Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 well theres been no coolant leak any more as yet so hopefully we shud be ok Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 well just been for a blast pull up at garage and guess what ! still leaking so whats the next suggestion ? i double checked all the hoses and retightened em up and still leaking argh! Quote
daz gt turbz Posted July 8, 2011 Posted July 8, 2011 that jubilee clip doesnt look tight?! i can see space between the clip and hose. Quote
daz gt turbz Posted July 8, 2011 Posted July 8, 2011 What I was gonna saygreat minds think alike! Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 haha but its as tight as it will go lol are the original clips any good ? cause if so ill whack one on Quote
daz gt turbz Posted July 8, 2011 Posted July 8, 2011 haha but its as tight as it will go lol are the original clips any good ? cause if so ill whack one onthats no where near tight by the looks of it mate, get another clip and swap them! Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 if this works ill love my car again lol and you guys Quote
Dan507 Posted July 8, 2011 Posted July 8, 2011 As above, it needs to be 'water tight' not just tight. Quote
nazzurro19 Posted July 8, 2011 Author Posted July 8, 2011 if i pull the top rad hose off and quickly put an old clip on will i lose much coolant? Quote
