few quick questions about glanza
A Few quick questions
1. whats the little red button near my steering wheel, dosnt do anything? (old alarm?)
2. Whats the "antenna" thing near my light thats on an extendable pole?
3. what model is mine? EPblah blah.. (P reg glanza)
4. i have a/c, but there is another button next to it called econ, whats that?
thanks in advance!
Cheers, the small switch isn't fog lights, i think it's maybe for an old alarm but not to sure. The car has clifford on the windows but there is no alarm fitted so I'm guessing the fella I bought it from took it out. The switch is just a small flick switch, has a red LED on it, and it's to the left of the steering wheel. (But not on the actual dash where the Hi/Lo boost and hazards are)
if you havent got a rear fog light then that red LED switch will be the fog switch. if you have a look under your rear bumper then the wires will be cable tied up under there somewhere. it was probably removed by the last owner and he left the switch there for when he needs to refit it for MOT.
