need oil seals replacing, where to go?
Hey guys. I've got the tong gt spec b turbo, unfortunately the oil seals have gone. Just wondered if anyone knew of any places that would replace them, every place I've rung so far has said "you will have to send it to us to see if we can do it" and to be honest I don't really want to send it somewhere for it to be stripped and them say we can't. Don't want to buy a new turbo either as I like this one :p
Thanks
  • 4 weeks later...
Or pm enzo, im sure he can supply seals if u needed. And any turbo place should be able to replace them, the likleyness of a turbo specialist like say turbotechnics not being ably to fix it is very very very slim!! Be a rubish turbo specialist otherwise.
it was unfixable, talking to enzo now about a replacement unit.
Lmao who told you that? Theres a fair few lads down this way with rebuilt ct9's and hybridised ct9's made and repaired by the bigger companies. Why would a bigger company offer all the different turbo service and repairs and then go leave out one of the toyota ct range?? Would be like doing all ihi subaru turbos but not the td04. Ricky may be able to do them but he isnt the only company buy a long shot. I've spoken to alot of turbo companies over the years and you would be suprised on the things they can offer on ct9's
Avensis TD 00-03 2.0LD
Avensis TD 97-01 2.0LD
HI-ACE 1998 2.4L TD
Hi-Ace 94- 2.4LD
Hi-Ace 94- 2.4LD
HI-LUX 1998 2.4L D
PICNIC 1997 2.2LD
Picnic 97-01 2.2LD
an example of a few of the toyotas running ct9's alot of the range where deisel engins, but the point im making is theres loads of toyotas using the ct9. an old friend of mine was going to replace my ct9 with one of a deisel engine when i firts got into starlets, till we realised it wasnt the turbo and was a different issue. as trisk says it is not possable for the seals to be un replaceable. try cr turbo's i spoke to them a few years back when they where going to build me a ct9/t3 hybrid.
