ilghap Posted September 22, 2011 Posted September 22, 2011 typed it in search but found nothing.so how hard is it to remove the wiper arm? Quote
LukeSR Posted September 22, 2011 Posted September 22, 2011 Not hard at all, lift the cap, undo bolt and pull.. Simple Quote
mattyD Posted September 22, 2011 Posted September 22, 2011 and take off the interior boot plastic, undo a couple of bolts and the motor pops out aswell Quote
Johnboy GT Posted September 22, 2011 Posted September 22, 2011 remember and fold over the water hose and tie wrap it tight. Leaky water all over the boot isnt cool if you accidentally pull the stalk! Quote
LukeSR Posted September 22, 2011 Posted September 22, 2011 remember and fold over the water hose and tie wrap it tight. Leaky water all over the boot isnt cool if you accidentally pull the stalk!What? Just leave it plugged in and don't touch the stalk.. Quote
ilghap Posted September 22, 2011 Author Posted September 22, 2011 What? Just leave it plugged in and don't touch the stalk.. Yeah, I forgot to ask about leakage. so if I just undo the bolt and lift the arm off, I can leave everything as it is without water getting in? Quote
LukeSR Posted September 23, 2011 Posted September 23, 2011 Yeah, I forgot to ask about leakage. so if I just undo the bolt and lift the arm off, I can leave everything as it is without water getting in?Well yes but you will have to remove the rear wiper motor and bung it up.. No need to touch the rear washer jet/pipe Quote
ilghap Posted September 23, 2011 Author Posted September 23, 2011 oh OK. do you know what kind of bung I need like size? Quote
Stui White Posted September 23, 2011 Posted September 23, 2011 I used a 28mm and its a little loose - 32mm will squeeze in lovely Quote
*Zoe* Posted September 23, 2011 Posted September 23, 2011 i have been meaning to ask this to, mine stopped working so just thought i would remove it.were would i get the bung from? Quote
Johnboy GT Posted September 23, 2011 Posted September 23, 2011 Was only a precaution! Obviously Im not goin to operate the stalk Quote
ilghap Posted September 23, 2011 Author Posted September 23, 2011 Cool Thanks. I will get on it when I get my GT back on the road Quote
