for my N/A
set the ride height as you want, i went for 40mm on the rear and 35mm on the front (the thread gap is what i went by)
iirc i have 6 clicks on the rear and 12 on the front (rear has a harder spring or something)
1- camber and zero toe
oh and loosen everything off and throw plenty of copper grease on then cut a old inner tube up and tie clip it on to the threads
I have mine on 0.5 camber 0 toe on the front is 18 clicks from soft and 13 on the rear the ride height is the same as out of the box
handles awesome.
handles awesome.
mine are 1t -1.3 deg camber and i believe we set them 2/3's i cant rember total clicks! eithere way driving style will mean they need tweaking but you will only know this once your driving it! its all about fiddling t get them right for you! :)
for my N/A
Quality idea an done :)
John
