Just got my engine back from the engineers
Hello all,
As above i thought i would share some pics,
Any feedback and thoughts welcome!
The block has been bored out to 75mm, new block plugs, Arp crank studs and re-linebored also chemically cleaned and fully tested etc...
The head has been chemilcally cleaned crack, presssure and vacume tested bench and flowed etc with identical combustion across all 4 chambers, valve seats re-cut with cnc and a 1 off direct fit custom head stud kit (not 4a-ge studs as they are not a direct fit) and cruise springs also ported and polished on exhaust side (still awaiting cams and solid buckets)
Pistons rods all Arp connectors, bearings and reground crank fully balanced
Sump and strainer chemically cleaned
Loads more stuff to come will update soon (hopefully ready for summer 2012)
  sam2kk8 said:
Looks lushh!
Looks lushh!
How much all that set you back?
And who did you send it too?
Thanx mate,
cant say how much it cost,
it was done through a mate of mine if you need any work doing let me know il get you quote
  micky boy said:
Haha just abit then lol get ya build thread back on the go would be nice to see how you get on over the upcomeing months!!
Will do soon as soon as i have made some more progress!
