WallaceGlanza Posted May 10, 2012 Posted May 10, 2012 So I finally got round to looking at fitting the powerflex bushes to my glanza, now I expected them to be too big as above but it's not quite as straight forward as just turning the diameter of the bush down slightly;First up the bushes measure basically exactly the same outer diameter as the metal sleeve which the standard bushes fit in:So as mentioned above they would fit within the small flange on the axle, however I still think this is not a good idea with the flange being so narrow the load is not being spread across the bush.So the OD of the powerflex bush is:56mmID of the metal sleeve is:About 48.5mm.So turning the bush down to 49mm would make it a nice interference fit.But on further inspection the width of the sleeve differs to that of the bush between the lips, this will explain it better;So if the bush was fitted with just the OD turned down there would be a nasty gap between the two halves of the bush giving it room to flex;Plus the bush would stick out too far to fit in the chassis mounts.Therefore each halve will need to be turned down to an OD of 49mm for a length of 22mm, which may hopefully still leave a small lip on the edge of the bush to help locate it and stop the axle having the possibility to move across the bush.I've written this mostly so I remember what I need to get done and once I have will post up here how it goes. Boring stuff over you can laugh at the use of the words bush, flange and lips whilst trying to write something informative! Quote
cazzac2222 Posted May 10, 2012 Posted May 10, 2012 Very interesting stuff there mate Let me know how you get one, may also be a good idea to send the info over to powerflex, maybe they could do something with it to amend!! Quote
Guard1an Posted May 11, 2012 Posted May 11, 2012 No no no...you are missing something, the total width of the bush and the mounting position.Oem and powerflex bushes are both 60mm in width so if you want to turn the bush down to fit in the ring you must also grind the sides of the ring about 3mm to fit the bush correctly into the mounting position.To fit mine i took measurements from old bush, took the ring out, made two new rings and weld them in the axle and now is perfect. Here are some photos to show you: Quote
WallaceGlanza Posted May 11, 2012 Posted May 11, 2012 (edited) That would be the best way to do it -but I can't weld! Very tidy job you've made of it though and I wish my car was so clean underneath, the UK weather/salty roads is awful for cars. I know the overall width would be too big if I just turned the OD - that's what I mention after the last photo. I was going to get the whole diameter that sits in the ring turned down to suit and remove a bit of the tapered lip too, I'm not sure if it will leave a lip though but it's maybe not completely necessary.I have also contacted powerflex and they may have another bush which would fit straight in but I'm trying to sort a deal with them! Edited May 11, 2012 by WallaceGlanza Quote
5sgte Posted June 5, 2012 Posted June 5, 2012 Anymore info on this yet, I'm keen to do these bushes but need to be sure I'm using the appropriate parts. Quote
WallaceGlanza Posted June 30, 2012 Posted June 30, 2012 (edited) So I contacted poweflex about this as I said and on Friday I got a sample kit through to trial fit, which I did and fit they do...Firstly comparison of the two bushes, GT on the right glanza on the left:A more obvious comparison:And bushes fitted:They fit perfectly, nice and tight but the axle still pivots freely - no road test yet though and there won't be for a few weeks as the car has many bits missing!Powerflex should now be putting these into production for the glanza soon. Edited June 30, 2012 by WallaceGlanza Quote
mattyD Posted June 30, 2012 Posted June 30, 2012 awesome mate, i do believe powerflex have just bought these out for retail now aswell Quote
