akyakapotter Posted January 24, 2012 Posted January 24, 2012 Ok so my Glanza's throttle response seams to be very poor at the moment anyone have any idea on what it could be it takes ages for it to pick up of the mark any help would be much thanked cheers nick Quote
ste91 Posted January 24, 2012 Posted January 24, 2012 Have you checked the basics i.e. ignition system parts? (Plugs/leads/etc...) Quote
akyakapotter Posted January 24, 2012 Author Posted January 24, 2012 No I haven't checked anything yet yeah I have a boost gauge it holds a bar no probs and dosen't drop Quote
shorty Posted January 24, 2012 Posted January 24, 2012 Strched throtle cable? Or maybe loose tps/map sensor plug? Other than that ignition basics. Quote
akyakapotter Posted January 24, 2012 Author Posted January 24, 2012 I will have a look when I get the chance it's only when pulling off from stand still when in up to speed its fine just a bit strange Quote
Flaminsam Posted January 24, 2012 Posted January 24, 2012 check the adjustment on the throttle cable, also if you want to set up the TPS you will need a multimeter. at idle it should read around 0.5v at WOT it should be around 4.5-5v. il do a thread on adjusting it at some point. chances are your throttle will not be opening fully as the cable will be slack. Quote
akyakapotter Posted January 24, 2012 Author Posted January 24, 2012 i hope its just the cable ill check :-) Quote
Flaminsam Posted January 24, 2012 Posted January 24, 2012 yea try not to worry too much about it. the cable on my girlfriends advance was really slack. we adjusted it and now it pulls like a train Quote
akyakapotter Posted January 24, 2012 Author Posted January 24, 2012 I'll get out there with a torch after the gym lol :-) Quote
akyakapotter Posted January 24, 2012 Author Posted January 24, 2012 looks like it is my throttel cabble its quite loose job for tomorrow then :-D Quote
