sosolid Posted February 11, 2012 Share Posted February 11, 2012 i get a knocking noise from the front nearside wheel when turning right. its not tool loud. is it the bearings and how dangerous if i continue to drive it like dat a bit more. also is it easy to fix? Quote Link to post Share on other sites
mattyD Posted February 11, 2012 Share Posted February 11, 2012 could be a cv joint Quote Link to post Share on other sites
tom_1593 Posted February 11, 2012 Share Posted February 11, 2012 I would defo say cv joint if it only knocks when turning. Quote Link to post Share on other sites
LeeroyV Posted February 11, 2012 Share Posted February 11, 2012 my front offside has just started to knock .... are the CV joints difficult to replace?? Quote Link to post Share on other sites
5T4R7ET N/A Posted February 11, 2012 Share Posted February 11, 2012 ^^ if you have the right tools then they are not difficult to replace. the hardest bit it getting the hub nut off.watch some youtube vids to give you a idea Quote Link to post Share on other sites
aaddzz123 Posted February 11, 2012 Share Posted February 11, 2012 If its more of a clicking then yeah it'll be the CV joint. As said above, realitively easy to replace the CV joint although I just changed both shafts when mine went because I found some cheap lol.If its more of a banging then it'll either be trackrod end or ball joint.Best bet is to move the wheel side to side as hard as you can (the actual wheel not steering wheel lol) and get a friend to put their hand over the joints to see if any have play Quote Link to post Share on other sites
funny onion Posted February 11, 2012 Share Posted February 11, 2012 when my CV went, it sounded like the noise donkeys make haha. Quote Link to post Share on other sites
rinseep82 Posted February 11, 2012 Share Posted February 11, 2012 Jack the car up dude and give the wheel a shake just check its not the bearing befor u go buying cv joints Quote Link to post Share on other sites
micky boy Posted February 11, 2012 Share Posted February 11, 2012 Cv joints clickWheels bearings hummTrack rods knockBotton Ball joints knockDampers knockCould be any of the 3 that knock...By anychance have you checked to make sure the big main bolt on the suspension strut it nice and tight? Quote Link to post Share on other sites
