Zeldoz Posted February 28, 2012 Share Posted February 28, 2012 Bought some Glanza electric folding mirrors! From Socks! So I'm baffled as how to make these works as in guessing in the Glanza it would have the existing plugs which plug into the mirrors then into the switch...I have two pictures with the back of the switch, and also the wing mirrors plugs. How could I make them work?.. Would appreciate the help! ...Thanks Quote Link to post Share on other sites
morgey Posted February 28, 2012 Share Posted February 28, 2012 Im interested in this also, but im pretty sure theres a control relay somewhere behind the dash thats needed, and also ideally the glanza loom would need to be mimic'd pin to pin from each mirror to relay and relay to switch. Plus power feeds.So wiring diagram and let us know whether or not there is a relay aswel? Quote Link to post Share on other sites
Zeldoz Posted February 28, 2012 Author Share Posted February 28, 2012 I was hoping the Glanza loom wasn't needed or a relay.Was kind of hopin some kind of bodge could be made, spading the connectors ect... Surely from looking at wiring diagrams, you can see what the colour of wires do and therefore cut and splice them jnto our own 'mini loom' Lewis Quote Link to post Share on other sites
jimmymac101 Posted February 28, 2012 Share Posted February 28, 2012 I'm interested in this to been looking into glanza mirrors but never seen it done in an na Quote Link to post Share on other sites
morgey Posted February 28, 2012 Share Posted February 28, 2012 well I've got the plug on the back of the switch so i have the colours of them wires but i dont think they match any of the ones off of the mirrors :sim pretty sure theres a relay that we need plus a short section of the wires from that to copy from. Quote Link to post Share on other sites
Zeldoz Posted February 28, 2012 Author Share Posted February 28, 2012 Hopefully someone could enlighten us soon! Quote Link to post Share on other sites
Asad Posted February 29, 2012 Share Posted February 29, 2012 You need the control switch too with some of the loom on, im guessing mostOf the wires will match up with the switch Quote Link to post Share on other sites
the quiet achiever Posted February 29, 2012 Share Posted February 29, 2012 hi in he australian version the plugs are already in the loom the only wire missing is the flolding wire i had to make door looms up as i couldn`t buy otherwise it was just plug & play there is wiring dia around on AU starlet site will have a look later if you can`t find it lyle Quote Link to post Share on other sites
Zeldoz Posted February 29, 2012 Author Share Posted February 29, 2012 In the picture the item on the left with a blue plug is the back of the connector.Would appreciate the diagrams lyle! ThanksItem on the left is the SWITCH I mean! Quote Link to post Share on other sites
ryan lang Posted February 29, 2012 Share Posted February 29, 2012 lukeP may have a wiring diagram, as he managed to get his glanza mirrors to fold when the ignition was turned off and fold out when it was turned on Quote Link to post Share on other sites
the quiet achiever Posted February 29, 2012 Share Posted February 29, 2012 hi see if the following helps you check & test your set-up ..-----1st column is mirror wires , 2nd column is dash loom-----Right hand side..Brown to Green/black stripeblue to green/white stripered to greenblack to green/red stripegreen to green/yellow stripeLeft hand side..brown to pink/black stripered to pale greenblue to green/white stripeblack to pinkgreen to green/yellow stripe hope this helps you all lyle Quote Link to post Share on other sites
Zeldoz Posted February 29, 2012 Author Share Posted February 29, 2012 Right thanks lyle!I was actually hoping instead of having themWork of the ignition, intact they can be made to work as per usual! I.e from the switch ect.. Any other input!? Quote Link to post Share on other sites
EP91Bon Posted March 5, 2012 Share Posted March 5, 2012 You not able to just power them to open and use a switch to control when u want them to shut? Quote Link to post Share on other sites
Zeldoz Posted March 5, 2012 Author Share Posted March 5, 2012 That is possible yes, but me being a perfectionist I would love to make use of the OEM switch which I have with them..You can easily wire them to ignition so when it's on there open and off they close. It looks like that's what I'm going to have to do In fairness.. Quote Link to post Share on other sites
FreedomCore Posted June 23, 2012 Share Posted June 23, 2012 So this is why you sold me those mirrors. Looks like ill be hijacking this thread Quote Link to post Share on other sites
Matts Posted June 26, 2012 Share Posted June 26, 2012 i'm also intrested in this if anyone has answers? If not ill give it a shot Quote Link to post Share on other sites
lukEp Posted September 5, 2015 Share Posted September 5, 2015 (edited) Resurrection of an old tread. Who's still interested in this. As I'm currently working on this with my SR and have successfully traced back the mirror switch PCB and figured out what wire does what and got it all working on my living room floor including retract/fold function. I've been taking pictures and I'm making the loom up so it's plug and play for my SR. I've been an auto electrician for over 15 years now so I know what I'm doing hopefully I'll be able to make the guide so you can DIY. Reading back at what Ryan lang said I'd made the mirrors on my glanza fold with the lock and unlock function of my alarm not the ignition. http://s663.photobucket.com/user/luke200381/media/FGMOUKSG/c844d87d.mp4.html Edited September 5, 2015 by lukEp Quote Link to post Share on other sites
morgey Posted September 5, 2015 Share Posted September 5, 2015 Good work, I've wired it all up in my Sr, the passenger side footwell plug didnt have enough pins in it so i had to get a bigger plug and repin all the old with the added mirror wiring. I got the power from the fusebox under the steering wheel and earthed it in the kick panel. You'll need to run the wires across the car to the pass and drivers kick panel to plug into the door plugs as well. A proper guide would be spot on though so take lots of notes lol Quote Link to post Share on other sites
lukEp Posted September 5, 2015 Share Posted September 5, 2015 (edited) Yeah mine has the plug on the passenger side same as drivers. Yeah I've already made a loom to feed the passenger side and cut the right plugs out of a paseo to make it plug and play. The wires are already in the doors for folding mirrors as well. Edited September 5, 2015 by lukEp Quote Link to post Share on other sites
Socks Posted September 5, 2015 Share Posted September 5, 2015 Write a guide Luke? maybe? Be very helpful im sure! Quote Link to post Share on other sites
morgey Posted September 5, 2015 Share Posted September 5, 2015 My pass side door was missing a few wires for the folding part of the system but you might be lucky Quote Link to post Share on other sites
lukEp Posted September 5, 2015 Share Posted September 5, 2015 Well you were right. Two wires missing on the passenger door loom. But all sorted now. BeforeDuringafter Quote Link to post Share on other sites
